![]() Drives: 2011 1SS RS Synergy Join Date: Aug 2010
Anyone have two step electronics on supercharged application
Anyone with two step electronics on a supercharged car? What are you using and how is it working out with a supercharger?
I'm considering either a lnc3 or MSD paired with a ctap. |
I have a MSD and it works good for what it is. Easy setup
![]() Drives: 2010 Camaro SS Join Date: Feb 2018
I have a lingenfelter two step on my 2010 M6 and have it activated through the e-brake lever. I forget what model I have though without going out in the parking lot at work and looking.
![]() Drives: 2011 1SS RS Camaro, 1995 LSX 240SX Join Date: Mar 2011
LNC2000 and the activation is on a button on the shift knob.
2011 Camaro 1SS
Whipple Supercharged 1150/1100 @ 24psi - Removed blower and went Turbo Huron Speed T6 1135/1070 @ 20psi so far. 15 more PSI loading... |
#6 |
Thanks for the replies!
#7 |
Cong Ty CP In Nguyen Gia
Drives: camarosports Join Date: May 2020
Hi. You can use MSD.
The MSD Ignition features a capacitor which is quickly charged (within one millisecond) with 460 - 480 volts and stores it until the ignition is triggered. With the CD design, the voltage sent to the coil is always at full power even at high rpm.
#8 |
LNC with CTAP works great once you get the CTAP set properly
