Old 05-12-2020, 08:46 AM   #1
Cash1333
Drives: 850whp Z06, 2014 Camaro ZL1
fuel related check engine light
So I am running into fueling issues it seems and I am not sure what's wrong. Under normal driving everything is fine but with driving hard I get a check engine light. The car would still drive the same, however codes P018B and P069E would pop up. Anyone else had this issue? My car has btr cam, ported snout, ID850, exhaust and pullied, makes 600whp.
Cash1333 is offline   Reply With Quote
Old 05-12-2020, 09:23 AM   #2
JB'sZL1
Drives: 2013 ZL1 and 2019 Ram Laramie
P018B is probably either pressure sensor or pump. All that's left is the FPCM.
JB'sZL1 is offline   Reply With Quote
Old 05-12-2020, 09:58 AM   #3
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
Where's your BAP?
ZMEnow is offline   Reply With Quote
Old 05-12-2020, 10:05 AM   #4
Juiced1
Drives: 2012 2SS CAMARO 45th
You might be dropping fuel pressure. I'd get a reading on it and see whats going on. Or it could just be a faulty sensor.
Juiced1 is offline   Reply With Quote
Old 05-12-2020, 10:15 AM   #5
JANNETTYRACING
JANNETTYRACING's Avatar
Originally Posted by ZMEnow View Post
Where's your BAP?
This, your losing fuel pressure big time, Danger Kitty.
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 05-12-2020, 11:23 AM   #6
Cash1333
I do not have one, I've honestly haven't looked into it due to putting all my time into my Z06. And I bought the car a year ago with how it is, and rarely drove it hard. But good to know to add a BAP.
Old 05-12-2020, 01:52 PM   #7
ZMEnow
Lean on Fuel, go boom. With the 850's you cant come close to holding 65psi on the rail. Someone took the cheap route in that build. Order one up from Ted..
Old 05-12-2020, 03:17 PM   #8
Cash1333
Yea ive decided to go flex fuel all together, so FIC 127lb injectors, flex fuel kit and dsx aux pump kit. So that should take care of the fueling issues all together.
C6 Z06 850whp
14 Zl1 600whp
Old 05-12-2020, 11:28 PM   #9
beersngars
Drives: 2012 ZL1
Good call on the DSX fuel system over a BAP. Happy with mine.
beersngars is offline   Reply With Quote
