05-13-2020, 03:20 PM | #1 |
Drives: 14 ss camaro summit white Join Date: Oct 2014
To be on the safe side would you choose...
Would u choose link bar lifters over the standard drop in tray lifters?
Im thinkin of pulling the trigger and getting some johnson link bars over there standard drop in lifter tray set up... pros and cons plz
2014 ss camaro
Stainless works long tubes , rotofab cai , vararam wedge , muffler delete,cat delete ,resonator delete , x pipe 2019 sierra duramax 2500 all terrain x 2001 trans am Lsx 408 ci rebuild in progress(dead project) 1967 camaro Sbc 327. |
05-13-2020, 03:54 PM | #2 |
I have the St2126LSR and love them. You will need to be tedious in setting up preload as they only require .035 +/- .005. Ive sent my motor to 8200 with BTR .660 springs no issue. If your looking for just a basic upgrade the regular bucket lifters are fine too. Doing a cam swap with the linkbars was easy with the rods.
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85 Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE 10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake Best 1/8 6.80@105.75 Best MPH 134.82 |
05-13-2020, 05:34 PM | #3 |
CamMotion makes link bar lifters for both LLSR and hydraulic applications as well. I have no idea how good they are though or if they are rebrands.
I think the hydraulic version is like $400.
