Old 05-13-2020, 06:43 PM   #1
Traven95
Drives: 2013 2ss ls3
Gauge help
So I don't know if this belongs here but it kinda pertains to this forum.
I not to long ago put a maggie on my 2013 l99. Gonna be diving into the enging with a ls3 conversion and cam plus other stuff to bump the power. But because I'm starting to do so many modifications I wanted to get some gauges for wideband AFR, IATs, Coolant and Trans temps. Just so I can be more In tune and aware of whats going on inside the vehicle. I know there are the gauge mounts for the pillar and also the steering wheel.
What I was wondering was, is there a digital display/screen that I can mount and have all of those parameters displayed on that?
Asumming it would just plug right up to the OBD2
Instead of having multiple gauges, I like the idea of a single screen with it all on hand.
I've been looking around and am finding full digital dash replacements but thats not exactly what I'm looking for.
Any help is appreciated
Traven95 is offline   Reply With Quote
Old 05-13-2020, 07:03 PM   #2
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
Autometer dash control can display any parameter in the hud, dic and radio. 4 in the hud, 4 in the dic 2 in the radio if you don't want a bunch of gauges. I use that and a pillar pod for wideband and boost
Greenhornet2 is offline   Reply With Quote
Old 05-14-2020, 11:11 AM   #3
blake-b
blake-b's Avatar
Drives: 2009 ZR1
Ngauge can display 6 parameters on one screen
Old 05-14-2020, 09:08 PM   #4
bayarea408
bayarea408's Avatar
Drives: T
Aeroforce interceptor gauge can show 2 stats at one time and covers all that you want plus a bunch more, i like to look at intake air temp and misfires with mine. I have a aem separate gauge and sensor to sniff out the wideband.
bayarea408 is offline   Reply With Quote
Old 05-15-2020, 09:02 AM   #5
rgrmoreira13
rgrmoreira13's Avatar
Drives: 2015 2SS 1LE
I have a Ngauge and I have it set up as a shift light. I have the parameters setup as IAT, coolant temp, AFR, engine temp, Fuel Pressure, and Boost
What makes it better is that you can display it all at once, you can store multiple tunes in your external SD card, run a diagnostic, and of course datalog your runs or even everyday driving.
Specs
TSP Stage 2 Boosted Cam 227/235 at 114 LSA
Fore Innovation Triple pump staged (Walbro 342 primary and 2x Walbro 450 secondaries)
Procharger D1x with a 3.85 pulley
ID1050x Injectors
Flex Fuel Sensor
Monster LT1 Twin Disk Clutch
Holley Sniper Efi Intake Manifold
NW 103mm Boosted TB
747rwhp at 12psi on E85
rgrmoreira13 is offline   Reply With Quote
Old 05-15-2020, 09:31 AM   #6
Greenhornet2
the dash control also displays it all at once, up to 10 things you can display, and no external gauge needed.
Old 05-16-2020, 01:04 PM   #7
blake-b
blake-b's Avatar
Drives: 2009 ZR1
I had both a dashlogic (same thing as the autometer) and the Ngauge. I sold the dashlogic because I didn't like having to scroll through things to see what I wanted.
If you aren't going to be logging or tuning the car, get the dashlogic/autometer as it is about $200 cheaper. Also get it if you already have HPTuners. The biggest difference is external gauge (ngauge) vs DIC/radio display (autometer)
I must qualify my statement and say I only had the Ngauge in my camaro. When I bought the vette, it had the dashlogic. I got rid of it and bought the ngauge. I cannot say how the dashlogic displays in the camaro.
https://www.autometer.com/dashcontro...2010-2015.html
https://www.google.com/search?q=hp+t...hrome&ie=UTF-8
Old 05-16-2020, 05:38 PM   #8
Greenhornet2
I don't have to scroll. You set what things you want displayed with the config on your computer. 10 things can be displayed at one time, whatever you program it to display. You can have different profiles so you could have 10 different things on the next page and so on. There is no other function like logging or tuning tho.
Old 05-16-2020, 09:01 PM   #9
blake-b
blake-b's Avatar
Drives: 2009 ZR1
The vette's DIC is much smaller than the camaro's. It will only display 2 things at once. I cannot remember how many it would display in the HUD. I could not display on the radio because I had swapped in an Alpine head unit.
Old 05-17-2020, 09:24 AM   #10
Shodown
Shodown's Avatar
Drives: 2014 ZL1
I have an Aeroforce Interceptor and love it. For the money it can’t be beat. The Ngauge is super nice too though, just pricey.
2014 ZL1 M6: Roto Fab Intake, LS3 TB, Long Tube Headers, NPP, Mild 2 Wild, JMS BAP, SMG aux pump, ID 1050X Injectors, DSX Flex Fuel Sensor, 10.5" DSX Lower Pulley, Killer Chiller, Tuned by Ted at JRE, Pedders XA Extreme coilovers, Mickey Thompson Street S/S on Weld S71s
Shodown is offline   Reply With Quote
Old 05-18-2020, 12:34 PM   #11
Traven95
Thanks for all the input guys, I'll take a look at the options. Kinda leaning towards the dashlogic. I like the idea of being able to have a lot of values up and visible rather than one gauge with a few on it
