Old 05-13-2020, 10:49 PM   #1
sinisterlsx510
sinisterlsx510's Avatar
Drives: 14 ss camaro summit white
Is my cam i have sitting in my garage supercharger friendly
Cam Specs: 235/247, .649"/.629", 113 LSA
Planning on adding a zl1 supercharger to my L99
2014 ss camaro
Stainless works long tubes , rotofab cai , vararam wedge , muffler delete,cat delete ,resonator delete , x pipe
2019 sierra duramax 2500 all terrain x
2001 trans am
Lsx 408 ci rebuild in progress(dead project)
1967 camaro
Sbc 327.
sinisterlsx510 is offline   Reply With Quote
Old 05-14-2020, 11:11 AM   #2
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
It's not ideal for a pd supercharger but it will work.
Greenhornet2 is offline   Reply With Quote
Old 05-14-2020, 11:50 AM   #3
Russell James
Russell James's Avatar
With that much overlap it's going to be down on power from a blower cam, and crazy loud. You'd probably melt the cats pretty quick if running cats. I'd sell it and get a PD blower cam with wider LSA.
Old 05-14-2020, 01:08 PM   #4
sinisterlsx510
Gonna be running no cats cough cough
2014 ss camaro
2001 trans am
1967 camaro
Sbc 327.
Old 05-16-2020, 08:47 PM   #5
old motorhead
Drives: Maggie blown LS3 vette
That cam would make a good trot line weight. That's the only way I'd use it. It would make plenty of buck, shake, surge, and stumble. Probably impress the car show crowd if that's what you're after. It's got no place in a mildly boosted LS engine on the streets.
old motorhead is offline   Reply With Quote
Old 05-16-2020, 10:16 PM   #6
InFiD3ViL
InFiD3ViL's Avatar
On a blown car, for sure. Not sure if its a VVT cam, but that is the exact specs of the Texas Speed stage 4.2 VVT cam.
I wouldn't run it if I was going SC, but if staying NA that thing would be a monster up top.
https://www.texas-speed.com/p-5772-t...-camshaft.aspx
Old 05-17-2020, 01:33 PM   #7
KW Baraka
KW Baraka's Avatar
Drives: 2014 Chevy SS
…..I wouldn't run it if I was going SC.....
Agreed.
Going through the time, effort, money to install a supercharger, you might as well put a proper cam in it too.
Best of luck!
KW
1995 Impala SS -- Heads/Cam LS3
1996 Impala SS -- 398ci LL Solid Roller LT4
2014 Chevy SS --- 429ci Hydraulic Roller LS3
KW Baraka is offline   Reply With Quote
Old 05-17-2020, 07:58 PM   #8
Athletics101
Athletics101's Avatar
Drives: 5th Gen L99
Not ideal, but you’ll be fine. Slap it in.
LSA conversion 2.5 upper 10% lower, L99 converted to LS3. TSP 229/244 cam, TSP LS3 ported and milled heads milled .015,Kooks LT’s no cats, Roto Fab, Borla arak cat back. 3200 stall,Forgestar F14 18’s and drag radials, pedders coil overs, BMR trailing arms & adjustable toe rods, mildly stripped Interior 685/613 on E 610/571 on 91
Athletics101 is offline   Reply With Quote
Old 05-17-2020, 10:51 PM   #9
STALKER
STALKER's Avatar
Drives: 2023 Camaro ZL1 1LE
Get a cam that's better suited, and take full advantage of the blower
2014 Camaro SS Spring Edition LSX440ci
LSX Block, MAST 305 Black Labels, Exceldyne Valves, Diamond Pistons, Callies Crank & Rods, Cam Motion Cam, Johnson 2116LSR Lifters, Comp XDA Pushrods, Jesel Rockers, Mamo MSD, NW 102, Roto-Fab CAI, FAST 65# Injectors, ZL1 Fuel Pump, Kooks 2" Headers, Corsa Sport 3" Catback, Z28 Shifter, ZR1 Clutch, Katech LW Flywheel, 1LE 3.91 Diff, LPW Diff Cover, BMR - 1.4" Springs, LCA's, Trailing Arms, Toe Rods, Sway Bars, End Links, Diff Bushings, and Tunnel Brace, Z28/1LE Strut Tower Brace, Improved Racing Oil Cooler
2023 Camaro ZL1 / 1LE
Stock
STALKER is offline   Reply With Quote
