Old 05-14-2020, 01:22 PM   #1
Speedracer389
Drives: Chevy Camaro SS
Stabilitrak Noise
Hello, I recently replaced a wheel bearing on the front passenger side. I also replaced the speed sensor. Then after what I thought was a faulty wheel bearing I replaced the wheel bearing again. The reason I replaced it the second time is at 13 mph there is a clunk which sounds like the stabilitrak is activating. This always happens at 13-14 mph. It will activate several times if I stay at this speed. It even shows stabilitrak active sometimes. I thought it was a faulty speed sensor so I replaced it. I also made sure everything was clean when I reinstalled the bearing and sensor. I'm not sure what else to do. There are no other lights or codes being thrown.
I searched the forums and internet but could not find any issue similar to mine so I joined to post this question. My next step is to take it to the dealer.
Thank you for your help. 2014 Camaro SS, auto
Speedracer389 is offline   Reply With Quote
Old 05-14-2020, 02:10 PM   #2
CamaroBarb
Banned
Drives: cheby Camaro
Why did you replace it the 1st time? Did you use a GM wheel bearing? Also look carefully if something magnetic dust etc is stuck to the outside of the wheel bearing where the sensor reads. You can buy a small card you hold up next to it to see if all the magnetic segments are working.
CamaroBarb is offline   Reply With Quote
Old 05-15-2020, 12:10 AM   #3
Speedracer389
The wheel bearing was making a whirring noise like most bad wheel bearings too. I've done quite a few wheel bearings to other cars. This is not a GM part. I don't know anyone that uses OEM parts. Each wheel bearing I've tried to fix the new issue has been a different brand. Haven't tried the card trick but now that it is back in then I won't be able to without pulling it again. Also because it made the stabilitrak noise with two different bearings I think it is a fault is somewhere else. Not really sure. I made sure everything is very clean when I installed the new bearing. Nothing seems to be in the way of the magnet.
Old 05-15-2020, 03:34 AM   #4
seothevinh
Cong Ty CP In Nguyen Gia
Drives: camarosports
Hello. Change tires to reduce noise in cars
Some types of tires always make noise and on bumpy roads, different types of tires will cause different noise levels. In addition, the deviation of the wheel angle also leads to a change in the friction surface of the tire with the road and leads to a higher noise level. Too inflated or too young tires can also greatly affect the noise level of tires during operation.
seothevinh is offline   Reply With Quote
Old 05-15-2020, 11:30 AM   #5
CamaroBarb
Banned
Heres the thing Speed, you didn't have the error with the original wheel bearing so there must be some kind of variation the sensor is seeing to set off the stabiltrak. As odd as it sounds try reinstalling the factory part to see if it goes away or try a OEM part. You could take it to someone with the proper scanner to actually see what is going on too.
Old 05-15-2020, 03:02 PM   #6
Speedracer389
That is a good point Barb. It wasn't making the noise before the new part. I guess I'm wondering if I have to reset or reprogram the stabilitrak after installing a new wheel speed sensor. One would think it would make a lot more fuss then just happening at 13 mph. Also if I turn off the traction control by hitting the button once it will not activate or make the noise at 13 mph.
Old 05-15-2020, 08:30 PM   #7
CamaroBarb
Banned
I'd count the number of segments and compare them.
Old 05-17-2020, 09:56 AM   #8
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
I would suspect the new sensor, not the new bearing.
Or the connector to the speed sensor. Check the connectors for damaged or dirty contacts, but also, is the sensor OEM? If there's one place to stay with OEM parts, it's electronics.
Rock-It Man is offline   Reply With Quote
Old 05-17-2020, 11:11 AM   #9
CamaroBarb
Banned
Good point, I missed he changed the sensor. Could definitely be it.
Old 08-02-2023, 12:40 AM   #10
linvol20
linvol20's Avatar
Drives: 2013
Anyone know what was the final fix?
linvol20 is offline   Reply With Quote
Old 08-02-2023, 10:53 AM   #11
Speedracer389
Fix!!
Yes! I took it to a dealer and they found a chunk of rust had attached itself to the back of the wheel bearing where the speed sensor is. Apparently this messed up the reading on the sensor. You would think this was random but I left with it fixed and it happened again! They cleaned it again and I never had the issue again.
stabilitrak, wheel speed sensor
