Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > Canada > Local Marketplace
Old 05-14-2020, 02:16 PM   #1
KillboyPowerhead
Drives: 2015 Z/22
Tires, Rear Diffuser and Tips For Sale
***Diffuser is sold***
Hello,
Please see the following links for:
Continental ExtremeContact DWS 06 tires: https://www.camaro5.com/forums/showthread.php?t=575395
Stainless exhaust tips: https://www.camaro5.com/forums/showthread.php?t=575394
KillboyPowerhead is offline   Reply With Quote
