Old 05-14-2020, 06:01 PM   #1
Ray299
Drives: 2011 SS
Exhaust???
Hey people, I'm a newbie here. First post. I have a 2011 SS. The exhaust is horribly quiet. So much so that you can't even tell it's running. When I bought it I had to pop the hood to make sure there was eight cylinders in there. is this normal? Is this what stock sounds like? Did somebody buy an aftermarket exhaust that makes it sound quieter? I mean, it's embarrassing...I don't want open headers but I want a rumble when it starts and I want to be able to hear it when I pull away.... Maybe even a little quicker performance.... Suggestions? Opinions?
Ray299 is offline   Reply With Quote
Old 05-14-2020, 06:40 PM   #2
acutron42
acutron42's Avatar
Drives: 2013 Camaro 2SS AGM
If you poke around here you will find threads that will last you days on this subject.
acutron42 is offline   Reply With Quote
Old 05-14-2020, 06:40 PM   #3
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
It is quite when stock. You can achieve a slight rumble with an axle back exhaust.
ECS supercharger, Texas speed stage 3 boosted cam, Johnson 2110 race style lifters, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
Camaro2ss2010 is offline   Reply With Quote
Old 05-14-2020, 06:42 PM   #4
acutron42
acutron42's Avatar
https://www.camaro5.com/forums/forumdisplay.php?f=72
Old 05-14-2020, 07:31 PM   #5
acutron42
acutron42's Avatar
I am new here also & have spent a ton of time looking around & thinking about mods. I have only had my 2013 2SS with 70k a few months & the first thing I might spend money on is replacing the stock oil pump. it might still be quiet but money well spent.
Old 05-14-2020, 07:35 PM   #6
Centauri
Drives: 2012 Camaro SS
It’s the quiet storm. Plenty fast, just not obnoxious
Centauri is offline   Reply With Quote
Old 05-14-2020, 07:37 PM   #7
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
Replacing the oil pump is the first thing you want to do with your car? Weird. :(
To the OP, are you manual or auto? For an auto car, if you put an X-pipe in place of the big resonator I bet you'll get some noise.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 05-14-2020, 07:47 PM   #8
InFiD3ViL
InFiD3ViL's Avatar
You have many options here. You may have to do a few other things to minimize unwanted drone from AFM activation if you have an automatic (L99) car. The manual cars come with an H pipe from the factory.
Prices are mainly affected by brand and quality of materials, but that is not set in stone. There are deals to be had.
Muffler delete - $100 - 200
Axle Back - $150 - 600
Cat Back - $300 - 1600 (This will also replace your factory resonator/H-pipe with an X-pipe in most cases)
There are also other routes you can go, such as catless downpipes, shorty or long tube headers. This is where many people (myself included) say to start off when making changes to your exhaust system, as it can have a drastic effect on the way your car sounds if you change mufflers before you do the headers, often times in an undesirable way (Car may be too loud or droney). The general rule to waste less money and have better overall results is to 'start at the front'.
Any changes to the headers or cat deletes via downpipes will offer a greater increase in performance than any muffler change will give.
There is a ton more info on this stuff available here and I am sure other members will offer their advice.
Welcome to the site btw!
Old 05-14-2020, 08:41 PM   #9
pyroguy
Keeper of “THE list”
pyroguy's Avatar
Drives: ABM #832
First off, welcome to the forums and congrats on your new to you ride!
Yeah, unfortunately the factory exhaust for a SS in 2010-2012 is embarrassing. '13+ you had the option for a better exhaust if you had a manual transmission. Personally I'm a fan of Solo Performance and their exhaust systems. Also, Stainless Works Retro Chambered catback is pretty nice too.
Check out my build thread
Old 05-14-2020, 09:26 PM   #10
oldman14ss
Drives: 2014 1ss camaro
solo performance cat back. loud when you stomp it. NO DRONE when cruising. best of both worlds.
oldman14ss is offline   Reply With Quote
Old 05-14-2020, 10:02 PM   #11
LCPLPunk
USA-1
LCPLPunk's Avatar
OP, here are Speed Engineering longtubes with an x-pipe with STOCK mufflers on my 2010 Camaro L99 (auto). I get compliments frequently on it.
Old 05-14-2020, 10:45 PM   #12
Cyber/Orange10
Cyber/orange10
Cyber/Orange10's Avatar
Drives: 2010 2SS 96 CE LT4, 12 CRUZE ECO
Send a message via AIM to Cyber/Orange10
SOLO is the way to go......
Cyber/Orange10 is offline   Reply With Quote
Old 05-15-2020, 08:17 AM   #13
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
high flow cats...period.
Old 05-15-2020, 10:12 AM   #14
myold88
myold88's Avatar
That's what I've had on my '10 SS L99 for almost 10 years now. The Solo
J/Pipe Axle Back exhaust. It's all you need to do for that old school muscle
car sound. One hour to install and no drone at any RPM.
