05-15-2020, 10:59 PM | #1 |
Drives: 2017 Summit White 1SS Join Date: Sep 2019
Canyon carver setup
Hey all!
I had a plans brewing in my head and I'm not sure how to carry it out. My car is a 1ss non MRC and I am looking to set it up for canyon carving and occasional auto-cross. I mainly want to stick with suspension, chassis and alignment mods as the camaro’s power is more than enough for my roads. I’ve been getting mixed messages across the board. I am hoping someone could shed some light on what the best mods/alignment setup for a canyon carver and occasional autocross use would be? |
05-16-2020, 12:19 AM | #2 |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
Solid rear cradle bushings, track alignment with -2.5 camber F & -1.5 camber R, sticky Extreme performance category 200 tread wear tires, stiffer sway bars.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
05-17-2020, 04:13 PM | #3 | |
Drives: 2017 1SS 1LE Join Date: Jun 2016
In addition to bars and rear cradle bushings there's also more suspension links/knuckles off the ZL1 1LE that could be swapped on to further stiffen your suspension due to stiffer bushings and spherical bearings being used in those parts. Lastly, there's also DSSV dampers, but the return per dollar on those isn't nearly as good as the other mods.
2017 SS 1LE.
05-20-2020, 02:58 PM | #4 |
Drives: 2017 Camaro SS 1LE Join Date: Oct 2018
Trade for 1LE, track alignment, solid cradle bushings.
Tags |
alighment, handling, suspension |
