Philippians 4:13
Drives: SLP Supercharged LS3 Join Date: Aug 2009
Popping noise from exhaust
I just put insurance back on my car today. I took it out for a spin and decided to hop on it a couple times because I haven't felt the power in quite a while. After I slowed down, the car every once in awhile does a loud pop or backfire.Even at idle it will do a pop maybe once every minute. I have no check engine lights on though. What do you think could cause something like this? Obviously I need to get it into see my tuner. I'm wondering if it has to do with the fuel that was put in at the end of the season last year. I cap it off at the end of the year before she goes into storage.
![]() Drives: 2015 Camaro 2SS RS 1LE AGM Join Date: Oct 2013
Did you put any fuel stabilizer in it? If not then yes the fuel is degraded. Add an octane booster.
Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
I would get fresh fuel in it before you start worrying much.
Drives: 2013 Sparkly Red One Join Date: Dec 2018
Decel pop?
