Old 05-17-2020, 07:47 AM   #1
Silverado60
Silverado60's Avatar
Drives: 2010 camaro 2SS/RS M6
Anyone using cam motion Titan 3?
I’m looking into doing a cam swap for my ls3 bolt on car. Just a weekend toy. I’m after low idle chop with decent gains. I’ve talked to TSP and GPI about their packages and both have been very helpful, but I don’t think a cam with maximum duration and/or lift is what I’m after.
Here’s the Titan specs
Duration - 227/237
Lift - .621/.604
Lobe separation - 113
Intake center line - 109.5
Texas speed F-35 cam, rollmaster timing set, melling hp pump, ls2 chain damper, fluid damper 25% under drive, Che rocker bushings, tsp .660 lift valve springs, BBK CAI Amzoil filter with Phastek ww relocation and scoop, Gmpp axle back, Speed engineering 1 7/8" LT's no cats, Peak speed shop ported tb, NGK tr6, MSD wires, Amsoil Zrod wix, heritage grill, 1.25" BMR springs, MRR 228, Nitto Nt05,dyno tuned by complete street performance, elite eng catch can, clean side separator, Hurst shifter, Zl1 addon wickerbill
Silverado60 is offline   Reply With Quote
Old 05-17-2020, 08:25 AM   #2
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
Why not contact btr and tell them exactly what you want they custom grind cams and hit the top of the mark for cam design knowledge.
Greenhornet2 is offline   Reply With Quote
Old 05-17-2020, 08:31 AM   #3
Silverado60
That’s pretty good advice Greenhornet2. I haven’t thought of that.
Did you run that blower cam any before you added the Whipple?
Old 05-17-2020, 08:43 AM   #4
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
Er...GPI sells four different cam lines, SS1-4, why not just pick a smaller one?
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 05-17-2020, 08:49 AM   #5
Silverado60
All stages of their ls3 cams have the same 646/.637 lift. I’m not interested in changing springs every 20k and I’m after a low idle.
This would be true with Texas speed though their stage 2 or 3 is definitely in the running.
Just don’t want to be kicking myself after the job is done
Old 05-17-2020, 09:28 AM   #6
07-SRT
07-SRT's Avatar
Drives: 2022 Camaro SS 1LE
I would still change springs out 20-25 k for insurance.
My previous 5th gen was a cam motion 226/236.
.629/.629 and I was recommended to change springs at that interval. That Titan cam is similar
2022 Camaro SS 1LE
07-SRT is offline   Reply With Quote
Old 05-17-2020, 09:36 AM   #7
Silverado60
Honestly I only put on about 2k a year. My car has 28k on it. So every 20k wouldn’t be the end of the world. So maybe a bigger cam is an option
Still wouldn’t want a high idle though
Old 05-17-2020, 10:18 AM   #8
Bo White
Bo White's Avatar
I've got 32k on my springs right now and I'm running the cam TSP puts in most NA race builds.
Old 05-17-2020, 10:27 AM   #9
Silverado60
Are you running.660 lift springs?
I’m just uneasy about running max lift and duration
Old 05-17-2020, 11:00 AM   #10
RupertPupkin
Drives: 2014 Camaro SS 1Le
Send it! Like you even said, you only put on 2k a year.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 05-17-2020, 11:10 AM   #11
Greenhornet2
Anything over .600 seems to be taxing on springs and they will need to be replaced. I didn't run this cam before i had the whipple. I was on the stock cam last year with the whipple. I don't like the cookie cutter cams but there is only so much you can do, unfortunately you can't have the best of all worlds with a can.
Old 05-17-2020, 11:24 AM   #12
07-SRT
07-SRT's Avatar
Way more than lift and duration involved.Different cam lobes like (EPS) and ramp rates can be easier on the the springs.. Also lighter Ferrera valves can help reduce stress on valve springs. Have to look at the whole set up
2022 Camaro SS 1LE
Old 05-17-2020, 11:24 AM   #13
Silverado60
Words to live by Rupertpupkin!
If I lean that way I really like the chop of the cam motion Titan king but it’s hard to go by you tube vids and I don’t have much performance data like tsp and gpi provide
Old 05-17-2020, 11:27 AM   #14
Silverado60
Agreed. Has anyone checked spring rates after 30k miles? Or is the main concern complete failure
