Old 05-18-2020, 01:27 PM   #1
co14camaro
Drives: 2014 Camaro
V6 MGW Install?
I've searched around and the majority of MGW short shifter posts are about the v8. Can someone with a v6 chime in on the install process? Does it pretty much follow the v8 instructions? And what are your impressions of the MGW shifter? I bought one and it just came in so just looking for advice and impressions. Thanks!
co14camaro is offline   Reply With Quote
Old 05-26-2020, 10:28 AM   #2
co14camaro
Drives: 2014 Camaro
Just wanted to say I got around to installing the MGW V6 Shifter. Overall I'm really impressed! Quality is top notch and everything was labeled and in baggies. Shifter has a nice mechanical feel and any rubberiness is completely gone! The install took a bit longer as no instructions were included and the only ones I could find online were for the V8 shifter. Problem is the OEM V6 shifter is very different than the V8 shifter so some of the instructions did not pertain to the V6. Also in some of the pictures it's very hard to see what is going on.
Overall if you track your Camaro at all I'd say the MGW shifter is a MUST! You will not believe the difference! The only place you can get the shifter is from BCS Auto, and Mike from BCS is the man! Very communicative when there were shipping delays.
