Old 05-22-2020, 09:14 PM   #1
Ernie70
Ernie70's Avatar
Drives: 2010 Synergy Green Camaro 1LT
Red face Battery keeps draining??
So , to back up a bit . back in December , I had vacation for 2 weeks and the car just sat. I went to start it and it was weak , so I jumped it no problem. Just chalked it up to it sitting and the cool weather. Fast forward to the quarantine days. I got laid off both my jobs ( I work in live and corp. production ) back in March , so she sits most of the time. I have noticed a pattern in the battery. If she sits for about 2 days , it is to the point of almost not starting, but it does. The battery is only about a year old , is an Interstate and wasn't cheap. Is there a constant drain when she sits , or do I have a fluke of a bad battery not even 2 years old ? She is bone stock with no aftermarket stereo or alarm . I have never had a battery go south for just sitting for 2 to 3 days. So a little confounded.
Ernie70 is offline   Reply With Quote
Old 05-22-2020, 10:12 PM   #2
Zspoiler
Zspoiler
Drives: 1979 Z-28 RS Camaro
I have a "loaded" 1981 El Camino that did the same thing .And it turned out that I had a short in my power seat that drained the battery . So I put the seat in the position I wanted and disconnected .until I have time to change my carpet .This may not be whats wrong but its a start .Good luck to you.
Zspoiler is offline   Reply With Quote
Old 05-23-2020, 01:10 AM   #3
PeteD
PeteD's Avatar
Drives: 2012 2SS Victory Red with white st
Well, if you bought it new, the battery should have a warranty. Have it checked and then replaced. if the battery is good then you will have to do a search for the power draw
PeteD is offline   Reply With Quote
Old 05-23-2020, 07:42 AM   #4
acutron42
acutron42's Avatar
Drives: 2013 Camaro 2SS AGM
I would check the battery ground strap in the trunk if you have not already.
acutron42 is offline   Reply With Quote
Old 05-23-2020, 06:48 PM   #5
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Even if your battery is new, you may not be driving enough to keep it charged. So, if possible, hook it up to a battery tender until your schedule allows more driving.
So many places and activities are shut down that long joy rides are one of the few things we can do. So go for some long rides.
Rock-It Man is offline   Reply With Quote
Old 05-23-2020, 07:36 PM   #6
Silveradoss573
Banned
Drives: Camaro 1LE
Mine drops to 50% after 2 weeks while sitting. I have to keep a battery tinder on it otherwise. Not sure if it's a battery issue or not? Been this way since I bought it almost 2 years ago.
Silveradoss573 is offline   Reply With Quote
Old 05-23-2020, 08:52 PM   #7
Avenging Orange
Avenging Orange's Avatar
Mine sits all winter and fires up at spring. Go figure.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 05-23-2020, 10:14 PM   #8
davidscamaro
davidscamaro's Avatar
Drives: 2010 SS/RS M6 BIG cam
Ive had very bad luck with interstate batterys , the mega tron 2 is junk in my experience
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
davidscamaro is offline   Reply With Quote
Old 05-23-2020, 10:15 PM   #9
davidscamaro
Must of replaced 3 in my c4 over two years. Was not impressed
Old 05-24-2020, 07:15 AM   #10
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
Perform a parasitic draw test and that will tell you if you have a draw while it's sitting. Disconnect the negative battery terminal, place a meter between the battery terminal and the now disconnected battery cable set to milliamps. The will always be some draw but if it's high then start pulling fuses and see if one makes the draw drop significantly then you know where to look. 2 days shouldn't draw down a battery much. You can also have the battery load tested it is possible it is a garbage battery. My car is on the original battery i believe and spend most of its like in storage, doesn't get driven in the winter and i've only had to charge it a couple times.
Greenhornet2 is offline   Reply With Quote
Old 06-04-2020, 11:40 AM   #11
Ernie70
Ernie70's Avatar
Thanks for all the advice guys! Going to try all your ideas to pin point the issue .
Old 06-05-2020, 08:56 AM   #12
Camaro__ss
Drives: 2013 L99
My 2005 corvette had this problem. Always needed a battery tender I could never figure it out. I think it was a a bad BCM. I traded it, that solved it for me.
Camaro__ss is offline   Reply With Quote
Old 12-27-2020, 08:23 PM   #13
RonHolz
RonHolz's Avatar
Drives: Chevy Camaro SS 2017
I have just bought a 2017 Camaro SS 6.2 Auto 8 speed. the battery went dead after sitting for 3 days, flat dead ,door opener would not work even. So I want to install the best battery I can get ? and I have a small batt. jumper I carry in my truck it has a plug in for the cigg lighter or I guess that would be a 12 Volt charging plug in now that is on the ft right of council, will that work to plug in my 12 Volt jumper to hold all my settings or should I take it to a shop to have the new battery installed, I do not want to fry anything. Does that Volt meter on the dash work, does that tell me the batter volts ? or charging volts ?
Thank you, I'm 73 and just finished a long battle with cancer and this has limited me to what I can lift or do now. the Camaro is like new with 13,000 miles. I always wanted one so I bought it for my get well present,LOL
Thank You for any help, the old grunt in WA. State.
RonHolz is offline   Reply With Quote
Old 12-28-2020, 10:27 AM   #14
Camaro__ss
Drives: 2013 L99
Take the car back to the dealer. It’s a lemon
