Old 05-24-2020, 05:47 PM   #1
CamaroJim56
Obsessed
CamaroJim56's Avatar
Drives: 2016 Hyper Blue 2SS RS
HVAC Blend Door
Anyone around the Tampa area ever fix one of these?
I think I have this problem, it's at a shop to be inspected, and they won't fix if it's this issue, I hear the dealerships charge around $2k. They pull windshield and dash out. Some have done this by cutting under the dash to access the door.
If anyone has done one of these and needs some money..... let me know.
Thanks,
Jim
https://www.camaro5.com/forums/showt...nd+door&page=5
2016 Hyper Blue 2SS
CamaroJim56 is offline   Reply With Quote
Old 05-25-2020, 02:46 AM   #2
'10CamaroDude
Drives: 2010 Camaro LS
Search the forums, this will be the 5th or 6th time covered. There is a video
that shows how to cut it out, and replace it.
'10CamaroDude is offline   Reply With Quote
Old 05-25-2020, 08:12 AM   #3
CamaroJim56
Obsessed
I read the posts, I am looking for someone in the area that has done it and would be willing to fix mine. Make some money, and save me some money. Don't feel comfortable tackling this myself.
2016 Hyper Blue 2SS
Old 05-25-2020, 10:30 PM   #4
Pbr
Pbr's Avatar
Drives: 45th anniversary
Find a good ac shop. My son had an evaporator leak . The AC shop did evaporator blend door and actuator for $1,500. They had the car for 2 days $145 of it was for the windshield shop they came removed it stored it and put it back in.
Pbr is offline   Reply With Quote
Old 06-03-2020, 01:59 PM   #5
CamaroJim56
Obsessed
Okay, in case someone stumbles onto this post and is looking for what I was, I paid $710 out the door. They do the cut through the bottom, no dash pull, Christian Brothers Automotive, in Brandon FL. They seem to have done a great job, I just picked it up. PM me if there are any questions.
2016 Hyper Blue 2SS
Old 10-19-2022, 09:46 PM   #6
TampaCamaro
Drives: Chevy Camaro
Hey bro. I also live in Tampa and my 2015 Chevy Camaro needs the Blend door replacement. So you said the shop in Brandon charged you 710 dollars?
TampaCamaro is offline   Reply With Quote
Old 11-03-2022, 07:22 PM   #7
theragtopguy
Lifetime Philly Fan
theragtopguy's Avatar
Drives: 2015 Spring Edition 2SS M-6
I live in Sebring and am not sure if the door is the problem.
It blows weak cool air after blowing hot air.
How can I be sure? I tried charging some 134a......didn't seem to take hardly any.
2015 Green Flash, Delivered 4/10/15
CAI, NPP Exhaust, Short-throw shifter
BBK LT HEADERS 1 7/8”
Tune by DynoSteve via SCTx4 Tuner
One of 82 GF Ragtops built in '15 out of 811 Total
[/SIZE]
theragtopguy is offline   Reply With Quote
Old 11-16-2023, 02:55 PM   #8
11/SS/RS
11/SS/RS's Avatar
Drives: 2011 Camaro 2SS/RS
Im a service writer at Top Wrench Automotive in Palm Bay and we do the work around repair as well.... Get in touch with us if you need this repair done.
11/SS/RS is offline   Reply With Quote
Old 12-02-2023, 02:01 PM   #9
myold88
myold88's Avatar
Good info even though my '10 SS blend door has been fine. I never touch the controls.
Just leave the temp control a notch above the blue dot. I'm not sure if this really works
like some here have suggested. I'm In SW Florida.
Old 12-02-2023, 02:14 PM   #10
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
I'm In SW Florida.
In my own experience, it has been working very well. I use mine fairly regularly, living in my particular area of the country. Spring through fall.
0stones0 is offline   Reply With Quote
Old 06-21-2024, 02:48 PM   #11
bludevl80
bludevl80's Avatar
Drives: 2010 Camaro SS
There is a a/c shop in Miami called Snow White. They did a friend of mine Camaro and I plan on taking mine there. Call them up.
Snow White Repair Center.
bludevl80 is offline   Reply With Quote
Old 08-09-2024, 09:52 PM   #12
JBEATZ
JBEATZ's Avatar
Drives: 2015 Chevy camaro 2ss commerative
im also from sebring GL fixing that it can be stress full but not to hard. I've done it my self but now seems to be damage again very annoying especially living in Florida's hot weather! now mines goes cold to warm then cold n its not even super cold so gota get it check GL do hope u fix it
JBEATZ is offline   Reply With Quote
Old 12-02-2025, 04:42 AM   #13
RedRockMan
Drives: 2015 Camaro 2LS, 1997 Z28 30th ed.
Anyone near Nashville/Murfreesboro TN who can do this.
I've got the classic broken blend door symptoms and am wondering if anyone knows of someone in the area who can do the "Cut Fix".
https://www.camaro5.com/forums/showthread.php?t=635848
TIA
RedRockMan is offline   Reply With Quote
Old 12-04-2025, 08:14 AM   #14
mr_honez
Wifey Lover
mr_honez's Avatar
Drives: 2013 2LT to 2SS Manual Conversion
Once it is fixed it does need to be calibrated or it will break again, an uncalibrated motor will go stop to stop and twist the door mount weakening it until it fails. A simple bi-directional scan tool can do it. Just FYI, it will also need to be done every time the battery is removed from what I have been told.
mr_honez is offline   Reply With Quote
