Old 05-25-2020, 03:07 PM   #1
Tony Camaro
Tony Camaro's Avatar
Drives: 2013 1LS
Name of bolt?
What's the name of the bolt that goes underneath the front bumper cover? There are two of them. Is it the lower deflector bolt? It's one of the bolts on this diagram.
https://www.gmpartsdirect.com/auto-p...nts-front-scat
Tony Camaro is offline   Reply With Quote
Old 05-25-2020, 03:50 PM   #2
Vegas Bound
Drives: 2013 Sparkly Red One
I count 12 different bolts on that diagram.
Vegas Bound is offline   Reply With Quote
Old 05-25-2020, 09:13 PM   #3
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
I think you are looking for number 16 in the following link.
https://www.wholesalegmpartsonline.c...ey_model=14491
ECS supercharger, Texas speed stage 3 boosted cam, Johnson 2110 race style lifters, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
Camaro2ss2010 is offline   Reply With Quote
Old 05-25-2020, 11:25 PM   #4
Tony Camaro
Drives: 2013 1LS
Yeah #16 has the same part no. as the lower deflector bolt. I think that's the one because 11610748, which is the next part, is the same nut that goes with it. I can get a bag of 10 on ebay for the same price as buying two from that GM site. I felt like a dumbass the other day because I didn't look there when I bought some retainer clips from a GM dealership. Ended up spending $50 for ten retainer clips when I could've gotten them for $10. Screw dealerships. Now I get why people call them "stealerships".
One more thing, I'm needing more of these bolts at the 2:00 timestamp in the video below:
As I was taking out the fender liner I noticed I only had one of these bolts on that same left side and two on the other side. How do you even lose these???
Old 05-27-2020, 10:33 AM   #5
Pearlj10
Drives: 2011 Camaro 2LT
Tony,
I think #8 in this diagram is the bolt you seek. Those bumper diagrams are not super clear when it comes to the fasteners. Check it out and see what you think.
https://www.wholesalegmpartsonline.c...roduct=2590913
Pearlj10 is offline   Reply With Quote
Old 06-22-2020, 06:08 AM   #6
Tony Camaro
Drives: 2013 1LS
#8 is a torx bit screw and those hold the wheel liner to the rocker panel. What I was looking for was a 10 mm. bolt with a big washer on it, but I found replacements for them.
