Old 05-25-2020, 05:39 PM   #1
judkins75
Silver Shark
judkins75's Avatar
Drives: 2014 2SS GM Npp 6 speed manual
430rwhp!!!#???
My current set up on my 2014 Camaro ss Ls3 Kooks long tube headers, Kooks hfc, Cai intake and scoop. My question is. How many crank HP is pushing out with 430rwhp dynoed at the wheels. Thank you all for your response. Just curious. .
Silver Shark20*10,20*11 Z28 black gloss replica wheels, 285/305 tires, BMR Strut brace,Kooks lt headers/hfc, CAI cold air intake/air scoop
judkins75 is offline   Reply With Quote
Old 05-25-2020, 05:48 PM   #2
InFiD3ViL
InFiD3ViL's Avatar
Calculated at the generally accepted 15% for a manual, around 495 crank.
Old 05-25-2020, 08:58 PM   #3
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #832
Why do you care about crank hp? It's just an estimate where wheel horsepower is an actual measured number.
Check out my build thread
Old 05-25-2020, 09:30 PM   #4
Camaro2ss2010
Camaro2ss2010's Avatar
Drives: 2010 Camaro 2SSRS M6
Curiosity kills the cat
ECS supercharger, Texas speed stage 3 boosted cam, Johnson 2110 race style lifters, ported throttle body, long tube headers, aeromotive fuel pump, fic injectors, ATI super damper, Corsa Extreme exhaust, elite engineering catch can and many other things.
Camaro2ss2010 is offline   Reply With Quote
Old 05-26-2020, 12:05 AM   #5
Tony Camaro
Tony Camaro's Avatar
Drives: 2013 1LS
You can always get a good estimate by dividing WHP by .8 if it's an auto or by .85 if it's a manual.
Tony Camaro is offline   Reply With Quote
Old 05-26-2020, 01:18 AM   #6
InFiD3ViL
InFiD3ViL's Avatar
I knew my estimate was off by a bit.
Old 05-26-2020, 09:54 AM   #7
Modernmusclecar
Modernmusclecar's Avatar
Drives: 2011 Camaro SS
430 whp seems a bit high.
Modernmusclecar is offline   Reply With Quote
Old 05-27-2020, 10:45 AM   #8
J Rod
J Rod's Avatar
Drives: '14 BRM 1LE 2SS/RS
Not too crazy for a 14-15 LS3, I hit 425 with bolt ons.
592 HP/590 TQ
LSA Blower w/ 2.45 Griptec, Reinforced Brick, FIC 1000 injectors, JRE FPCM, LFP Dual Pass HX, ZL1 IC pump, RotoFab CAI, Bo White TB, Coated Stainless Power 1-7/8" LTs, NPP, NGK TR7IX, Mighty Mouse Wild CC, AEM X-Series WB, Aeroforce Interceptor, MGW Shifter, Z28 Grill, Gary's Custom ZL1 Rockers, Hero Tails, Tuned by IMC
J Rod is offline   Reply With Quote
Old 05-27-2020, 12:53 PM   #9
xc_SS/RS
Drives: 2010 Camaro SS/RS
I know a guy who hit 460ish rwhp with two different stock cam and heads LS3. 430 is pretty normal
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 05-27-2020, 01:48 PM   #10
Camaro2ss2010
I was a little over 430 with the same mods and no cats before I had my cam and other mods.
Old 05-27-2020, 05:36 PM   #11
Spec
Drives: 2010 Camaro 1SS LS3
1/.85 = 1.1765 (rounded up)
1.1765 x 430rwhp ... so appx 506hp
The increase due to the increase in air/oxygen-flow and fuel.
Is that right? Because now people are going to say they have a 500+ horsepower car lol
Mine's settled at 426rwhp for now with bolt-ons and a tune...
Spec is offline   Reply With Quote
Old 05-27-2020, 08:19 PM   #12
daktah
daktah's Avatar
Drives: 2013 camaro 2ss 1le
well a 10 second glance at a handful of reported stock dynos, ls3+m6 averages around 370-375ish and l99+a6 averages around 325-330ish. so you can figure the loss factors as 12% for the m6 (426bhp÷375whp) and 18% for the a6 (400bhp÷330whp) with fair accuracy.
so you can assume to have roundabout 482bhp with a stick (430whp*1.12 aka 12%), without taking into account whatever error and variation your particular dyno will have.
also 12% loss is insanely good, i dont know if gm underrated the ls3 by a few horses or the 6060 is just THAT efficient somehow.
2013 Camaro 2SS 1LE w/ RS [Rally Yellow]
Stock + Speed Engineering 1 7/8 LTHs w/ TSP HFCs, Roto-Fab CAI, Innovate DLG1/LC2 Dual WBo2, Smoked Wicker Bill, Self Tuned w/ HPTuners
daktah is offline   Reply With Quote
Old 05-27-2020, 08:20 PM   #13
Warship2k15
Rwhp is only a number.On one dyno the same car could be at 370-380.
In my opinion they should only be used for comparison from before and after etc or if lots of people are using the same dyno you could compare your car to another with the exact same mods to see if you have any problems.
Other then that they should be taken with a grain of salt.
Warship2k15 is offline   Reply With Quote
Old 05-28-2020, 03:33 PM   #14
_Onyx_Wolf_
Onyx_Z7 <— Instagram
_Onyx_Wolf_'s Avatar
Drives: 2013 2ss 1le
A manual will make more power so I think you have it flipped.
_Onyx_Wolf_ is offline   Reply With Quote
