Old 05-26-2020, 01:03 PM   #1
rgrmoreira13
rgrmoreira13's Avatar
Drives: 2015 2SS 1LE
Throttle Body
I have a Nick Williams Boosted 102mm on its way. However I have a regular NW 102mm and when I am reading it off my gauge and I smash the pedal to the floor it reads at 85%.
I know this is a noob question but isn't WOT considered at 100% ?
So in addition to that question what is the usual Throttle Percentage when it's at idle or at WOT ?
I see mine at idle between 11- 18%
WOT between 79-85%
Could the TB be at it's last legs and needs to be fixed ?
Thanks in advance
Specs
TSP Stage 2 Boosted Cam 227/235 at 114 LSA
Fore Innovation Triple pump staged (Walbro 342 primary and 2x Walbro 450 secondaries)
Procharger D1x with a 3.85 pulley
ID1050x Injectors
Flex Fuel Sensor
Monster LT1 Twin Disk Clutch
Holley Sniper Efi Intake Manifold
NW 103mm Boosted TB
747rwhp at 12psi on E85
rgrmoreira13 is offline   Reply With Quote
Old 05-26-2020, 07:45 PM   #2
'10CamaroDude
Drives: 2010 Camaro LS
Originally Posted by Iam Broke View Post
It is reading the position of the Throttle Position Sensor, not your pedal. GM builds in some room in the sensor for calibration, manufacturing differences in sensors ect. Normal. If it goes to 0 or 100% it''ll set a code. That's how it can check itself. It knows the extremes are abnormal.
I'm sure your throttle blade is 100% open at 84% TPS
Was in the forums...
'10CamaroDude is offline   Reply With Quote
Old 05-27-2020, 02:43 PM   #3
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Yes, 19 or so at idle, 84 at WOT is normal. Log the SAE pid to get 0-100 if you want it.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp // CSP LT's & Ultra Cats // BMR MM // BC Forged KL13
Mods being installed-
oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc.
RobZL1 is offline   Reply With Quote
