Old 05-26-2020, 03:51 PM   #1
Maroon 6.2L SS
Maroon 6.2L SS's Avatar
Drives: 2010 Camaro SS A6
True Trac LSD and rear cradle bushings
Next week I'm having an Eaton True-Trac LSD and BMR rear cradle bushings installed on my auto. Do you know how much of a difference this install will make on my reaction time? I'm assuming it will launch out of the hole quicker.
Maroon 6.2L SS is offline   Reply With Quote
Old 05-26-2020, 04:53 PM   #2
StingrayblueSS
StingrayblueSS's Avatar
Drives: 2013 Camaro SS
It might help your 60' but reaction time is all you.
2013 Camaro SS
Kooks Headers Vararam DRX 1le Differential 3.91
Bo White throttle body Magnaflow Competition Exhaust
12.391 112 MPH 10/05/19
StingrayblueSS is offline   Reply With Quote
Old 05-26-2020, 05:14 PM   #3
Bufford
Drives: 1970 Buick GSX
Not entirely,...that play however minimal can play a part in breaking that beam... not so much a factor on an auto where your loading the suspension slightly. The faster the car reacts the more accurate you can be
Bufford is offline   Reply With Quote
Old 05-26-2020, 05:34 PM   #4
Silveradoss573
Banned
Drives: Camaro 1LE
Not enough to notice would be my guess.
Silveradoss573 is offline   Reply With Quote
Old 05-28-2020, 03:15 PM   #5
Joe M 2012 2SS
Joe M 2012 2SS's Avatar
Drives: 2012 2SS
You wont get any quicker throttle response from the True-Trac or the bushings.
The True Trac will allow you to do more consistent burnouts, and will allow the car to launch dead straight every time.
The bushings will stiffen up the differential to avoid excessive movement, the car will feel much stiffer during normal driving, and you'll also hear more noise from the rear end.
Since your gutting the differential to put a True-Trac in, why not swap to a 3.91 gear while it's apart?
You will pick up 1 to 1.5 tenths in ET.
The only mod I've done that improved the throttle response was the Bo White Stage II throttle body, instead of leaving just before the 3rd yellow, I now leave at the 3rd yellow for same RT.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles.
Joe M 2012 2SS is offline   Reply With Quote
Old 05-28-2020, 07:03 PM   #6
Maroon 6.2L SS
Thanks all. I didn't think the RT would change much at all, but wasn't sure. I was looking for more consistency, stability, strength, equal traction on burnouts etc...etc...
Joe, I'm hoping next year to do the 3.91 gears and a updated Dyno Tune. With everything going on with the pandemic the wife set limits.
Old 05-28-2020, 08:27 PM   #7
Joe M 2012 2SS
Drives: 2012 2SS
Understandable.
But your going to pay a lot more next year than you would if you do it now, while the pumpkin is already removed and taken apart.
The AAM gear is less than $300. The extra labor to install the gear now shouldn't be very much at all, maybe an additional 30 minutes - 1 hour for setting the backlash and checking the pattern
If you wait until next year, your going to have to also get a new set of bearings, and shims. The labor cost will be a lot more, probably around $500 plus.
So pay $350 to $400 now, or $800+ next year.
