Old 12-22-2009, 12:20 PM   #1
philthy
philthy's Avatar
Drives: 1971 Monte Carlo/2010 Camaro 2LT
Winter tire package opinions?
Does anyone have any input on the preferred package that Tirerack.com has on their website for the Camaro?
I have a 2LT without the RS package. These seem like a great deal....
You Selected: 2010 Chevrolet Camaro LT 1LT Select New Vehicle
This Preferred Package has been selected by our fitment specialists and is designed to be an ideal winter solution for your vehicle. You can also build your own winter package.
Bridgestone Blizzak DM-V1 (Light Truck/SUV Studless Ice & Snow)
Sidewall
Style: Blackwall Size: 225/65-17 (4)
Serv. Desc: 102R Load Index 102 = 1874lbs (850kg) per tire
Speed Rating “R” = 106mph (170kph)
UTQG: Not required for
this tire.None Price: $428.00
Estimated Availability: In Stock
Optional Road Hazard Program: additional $12.84 per tire
moda EB1 (Bright Silver Paint)
View on
Vehicle Size: 17X8 (4)
Offset: 35mm
Backspacing: 5.90"
Bolt Pattern: 5-120
Weight: 22.6lbs.
View Important TPMS Info
Price: $316.00
Package Total: $744.00
(not including Road Hazard)
Home > Winter / Snow > Preferred Winter / Snow Package for 2010 Chevrolet Camaro LT 1LT
2024 Camaro SS convertible
2010 Camaro 2LT
2019 Cadillac CTS
1971 Monte Carlo
philthy is offline   Reply With Quote
Old 12-23-2009, 08:23 AM   #2
philthy
philthy's Avatar
Originally Posted by poonamt93 View Post
You are super, and will serve you well. You might want to have a look at Toyo's also.......the Chevrolet dealers here (Ottawa) sell Toyo winter tire packages, the Toyo winters are in the same league as the above.
For a 2010 Chevrolet Camaro, you can (and should) go down to a 15" wheel. 15's will be less expensive, and arguably better (Some say a smaller tires cut through snow slush better than a larger tire with a larger contact patch. The logic makes sence, but I don't have any data to back it up).
NOTE - the 2010 Chevrolet Camaro GT (with factory 17's) can not take 15's, you can only downsize the GT to 16"
Cheers.
Thanks for the reply, but just wanted to clarify your last note:
Chevrolet makes a Camaro SS, not GT.
Camaros do not come from the factory with 17" wheels...18" is the minimum available from the factory.
The SS can not take stock 18" wheels, but there are a limited amount of aftermarket wheels that will fit over the Brembo brakes.
Are you sure this is not being confused for a Mustang GT?
The above being clarified......
I have the 2LT without the RS package, so I trust Tirerack.com's recommendation for a 17" wheel package.
One thing that concerns me since my initial post is that another member changed his tires and immediately tripped a "service Stabilitrack system" code. I am hoping changing the wheel size below what came from the factory will not trip a code. The overall diameter is .1" within the factory specs, so not concerned with the speedometer being thrown off. Should I be concerned?
2010 Camaro 2LT
2019 Cadillac CTS
1971 Monte Carlo
Old 12-23-2009, 09:15 AM   #3
skuttduck
skuttduck's Avatar
Drives: 2010 RJT 2LT Camaro
Send a message via ICQ to skuttduck Send a message via AIM to skuttduck Send a message via Yahoo to skuttduck
Tirerack used to previously recommend the Pirelli Scorpion Ice and Snow on 18" rims.
It's interesting that there is a 17" Rim package now.
I can tell you I went with the 20" Pirelli Scorpion Ice and Snow installed on my stock rims, and that was the cheapest option I could do. I picked them up at Belle Tire here in Lansing. I did come across a set of 20" rims on Ebay, so I have those to use for my summer tires.
I've had no issues with the scorpions, aside from the TPMS reading a bit low, but I'm not worried about that. It isn't low enough I see any errors from the car, and checked the pressure with my tiregauge and compressor.
By the way, the pirelli scorpion winter tires perform great!
skuttduck is offline   Reply With Quote
Old 12-23-2009, 12:16 PM   #4
philthy
philthy's Avatar
Thanks for the input...20" are a little outside my budget.
The 17" package appears to be a great deal, provided it does not affect the car negatively.
2010 Camaro 2LT
2019 Cadillac CTS
1971 Monte Carlo
Old 12-24-2009, 01:10 PM   #5
Axe
Axe's Avatar
Drives: 2018 LS
I have a 2LT/RS and just checked this out today as well. $744 for snow tires and rims? Cant beat it.
Axe is offline   Reply With Quote
Old 12-24-2009, 01:15 PM   #6
bluch
OH CANADA!
bluch's Avatar
Drives: 2011 RAM 1500 LARAMIE
This is my thread with the info on my winter/rim set:
http://www.camaro5.com/forums/showthread.php?t=45533
And this is a thread with them installed on my 2LT RS:
http://www.camaro5.com/forums/showthread.php?t=47939
And this is a thread with snow pics...just to give an idea what kind of stuff im drivin in. They are handling great
http://www.camaro5.com/forums/showthread.php?t=57249
Had to trade in the Camaro for a truck :(, but hopefully I can join the Camaro family again one day
bluch is offline   Reply With Quote
Old 12-24-2009, 01:16 PM   #7
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
yeap, that was me. And yes, it was the "huge" difference in tire size that tripped the Stabilitrak code. (sarcastic there). I have a 2SS, and I kept the 275/40 in the rear, but went with a 255/35 in the front (comes with 245/45). That difference threw the code. I should have went with a 245/40, a 255/45, or another 245/45.. anything beyond those sizes will more than likely throw a code (or changed the rear to be a 275/35). Rim size needs to be consistant also, but no need to go on about that. damn car is too smart I tell you
Old 12-24-2009, 09:29 PM   #8
philthy
philthy's Avatar
So as long as all 4 tires are the same overall height it should be fine? I am thinking regardless of the wheel diameter, as long as the overall tire size is within .1" of stock, Stablitrack will not be affected.
I doubt Tirerack.com would sell a package that would throw a code....but it never hurts to ask around.
2010 Camaro 2LT
2019 Cadillac CTS
1971 Monte Carlo
OSHAWA Impala line employee question - CamaroScotty 5th Gen Camaro SS LS LT General Discussions 66 03-22-2009 10:08 AM
