Old 05-27-2020, 12:05 AM   #1
RupertPupkin
Drives: 2014 Camaro SS 1Le
Coilover install cost
Before you guys start saying “do it yourself...etc etc...”.......I’m pressed for time, and I lack the necessary tools to do coilovers. Emailed a couple of shops for pricing. What’s a reasonable price to get these done? OR if there’s any forum members in the Chicagoland area willing to do it, I’ll pay you $ plus beer/pizza...lol. I don’t mind paying people to do sh**, as long as it’s fair.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 05-27-2020, 05:43 AM   #2
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
You don't need any special tools. I'd say around 2 hours 3 max plus alignment. You may have to buy camber bolts for the rear tho
Greenhornet2 is offline   Reply With Quote
Old 05-27-2020, 11:00 AM   #3
RupertPupkin
Yeah. I have to source out some tools. Friend option is still on the table, but he hasn’t replied yet. 1 shop wanted 6hrs of labor at 150$/hr, plus 225$ for an alignment.
730whp: 630Trq
Old 05-27-2020, 01:09 PM   #4
InFiD3ViL
InFiD3ViL's Avatar
That's high, imo. Especially their estimate of 6 hours.
I won't lie, my coilovers kicked my ass. I did it in my driveway on jack stands and it took me the entire day. But I also ran into some stuck bolts and injuries lol. I also took multiple breaks and spent a bit of time measuring and adjusting for the amount of drop I wanted. I also cut into my trunk for the adjustment extensions and made sure the cuts were perfect, but many people skip the rear extensions and I totally get not wanting to cut into your trunk floorboard. But it did add to my overall time.
If I could do it again to save $150 per hour labor I certainly would. I see no reason why an experienced shop with a lift and proper tools would need 6 hours to do this. I spent $180 at a local Goodyear for the 3 year unlimited alignment and was happy with the results. Now when I add rear camber bolts I can go back and get it adjusted at no additional cost. A one time alignment would have cost me less than $100.
I would keep searching shops for better pricing if you are intent on having it done, as I think you can do better.
Old 05-27-2020, 01:51 PM   #5
RupertPupkin
Impact gun does wonders on builds. I can’t spend a whole day on this. I remeber when I had to swap out my rotors/brakes on my G8. Took me 6 hours since everything was seized, and it was 90* outside and humidity was at 100%. Felt like a Chinese worker in a factory.
550$ is the cheapest so far. Another shop wanted 940$ with alignment.
730whp: 630Trq
Old 05-27-2020, 02:07 PM   #6
Greenhornet2
$550 is reasonable. The front is a cake walk. Rear is a little tougher as it's a tight fit. I don't think it would take me more than 2.5 hours working on the ground with an electric impact. I did my lowering springs in about that and i had to swap the springs.
Old 05-27-2020, 02:40 PM   #7
InFiD3ViL
InFiD3ViL's Avatar
Yeah, $550 sounds fair for sure.
Old 05-27-2020, 02:55 PM   #8
RupertPupkin
That’s good to hear that 550$ is not too bad.
730whp: 630Trq
Old 05-27-2020, 04:53 PM   #9
Keoni068
Keoni068's Avatar
Drives: 2015 Camaro 2LT RS
I paid $400 for the install, including the installed trunk adjusters, and then $140 for the alignment at a different location. So it seems like you're getting a similar price!
Keoni068 is offline   Reply With Quote
Old 05-28-2020, 08:15 AM   #10
mbesman
Great White
mbesman's Avatar
Drives: 2015 Camaro 2SS
I paid about 500 for both install and alignment at Midas. Look for coupons also. I think that was 10% off.
mbesman is offline   Reply With Quote
Old 05-28-2020, 09:33 AM   #11
RupertPupkin
I sourced them out too, but they said they typically just do general oem stock stuff.
730whp: 630Trq
