![]() Drives: Bumblebee Join Date: Mar 2014
Need help torque specifications for LLT Engine
Hi,
Can anyone help me? I am rebuilding engine with new crank, rods pistons timing chaing etc. And i need torque specification for all Engine 3.6L V6 LLT 2010
Camaro LT2 RS
Transformers package Airlift bagged 22" Rohana RC22 BMW 325i Convertible |
A/C
Compressor Bolt - Rear - CTS Only 45 N.m 33 lb ft Compressor Bolt - Rear - All Except CTS 58 N.m 43 lb ft Compressor Bolt - Front 22 N.m 17 lb ft Compressor Bracket Bolt - Front 50 N.m 37 lb ft Compressor Hose Assembly Bolt 9 N.m 80 lb in Camshaft Cap Bolt 10 N.m 89 lb in Camshaft Cover Bolt 10 N.m 89 lb in Camshaft Intermediate Drive Sprocket Bolt - Idler Sprocket 58 N.m 43 lb ft Camshaft Position Actuator Camshaft Bolt 58 N.m 43 lb ft Oil Control Valve Bolt 10 N.m 89 lb in Camshaft Position Sensor Bolt 10 N.m 89 lb in Catalytic Converter Exhaust Manifold Nut 50 N.m 37 lb ft Close Out Cover Bolt 10 N.m 89 lb in Clutch Pressure Plate Bolts 30 N.m 22 lb ft Connecting Rod Bolt First Pass 30 N.m 22 lb ft Second Pass - Counterclockwise Back Off to Zero Third Pass 25 N.m 18 lb ft Final Pass 110 Degrees Coolant Outlet Bolt 10 N.m 89 lb in Crankshaft Balancer Bolt First Pass 100 N.m 74 lb ft Final Pass 150 Degrees Crankshaft Main Bearing Bolt - Inner First Pass 20 N.m 15 lb ft Final Pass 80 degrees Crankshaft Main Bearing Bolt - Outer First Pass 15 N.m 11 lb ft Final Pass 110 Degrees Crankshaft Main Bearing Bolt - Side First Pass 30 N.m 22 lb ft Final Pass 60 Degrees Crankshaft Position Sensor Bolt 10 N.m 89 lb in Crankshaft Rear Oil Seal Housing Bolt 10 N.m 89 lb in Cylinder Head Bolt - M8 First Pass 15 N.m 11 lb ft Final Pass 75 Degrees Cylinder Head Bolt - M11 First Pass 30 N.m 22 lb ft Final Pass 150 degrees Cylinder Head Core Hole Plug 31 N.m 23 lb ft Drive Belt Idler Pulley Bolt 58 N.m 43 lb ft Tensioner Bolt 58 N.m 43 lb ft ECM Bolt 10 N.m 89 lb in Bracket Bolt - Front 23 N.m 17 lb ft Bracket Bolt - Side 10 N.m 89 lb in Grounding Bolt 4.5 N.m 40 lb in ECT Sensor 30 N.m 22 lb ft Engine Flex Plate, Auto Trans, Bolt First Pass 30 N.m 22 lb ft Final Pass 45 Degrees Engine Flywheel, Manual Trans, Bolt 67 N.m 49 lb ft Engine Front Cover Studs 15 N.m 11 lb ft Engine Front Cover Bolt - M6 15 N.m 11 lb ft Engine Front Cover Bolt - M8 First Pass 20 N.m 14 lb ft Second Pass 20 N.m 14 lb ft Final Pass 60 Degrees Engine Front Cover Bolt - M12 65 N.m 48 lb ft Engine Mount Bracket Bolt to Engine Block - M8 (AWD) 38 N.m 28 lb ft Bracket Bolt to Engine Block - M8 (RWD) 22 N.m 16 lb ft Bracket Bolt to Engine Block - M10 60 N.m 45 lb ft Nut to Engine Mount Bracket 80 N.m 59 lb ft Nut to Frame 80 N.m 59 lb ft Engine Wiring Harness Bracket Bolt - Cylinder Head Rear 40 N.m 30 lb ft Bolt - ECM Bracket Side 23 N.m 17 lb ft Bolt - ECM Bracket Top 10 N.m 89 lb in Bolt - Left Side Oil Filter Adapter 10 N.m 89 lb in Bolt - Left Side Oil Pan 10 N.m 89 lb in Bolt - Near Crankshaft Position Sensor 50 N.m 37 lb ft Bolt - Right Side Block Front 23 N.m 17 lb ft Bolt - Right Side Head Front 10 N.m 89 lb in Engine Wiring Harness Ground Bolt - ECM Bracket Top 10 N.m 89 lb in Bolt - Left Cylinder Head Side 10 N.m 89 lb in Bolt - Right Cylinder Head Rear 10 N.m 89 lb in EVAP Purge Valve Bolt 10 N.m 89 lb in Exhaust Manifold Bolt 20 N.m 15 lb ft Heat Shield Bolt 10 N.m 89 lb in Lower Heat Shield, Knock Sensor Shield, Bolt 58 N.m 43 lb ft Fuel Injection Fuel Rail Fuel Pressure Sensor 33 N.m 25 lb ft Fuel Line Pressure Fuel Line Fitting Nuts 30 N.m 22 lb ft Fuel Pump Bolts - High Pressure 15 N.m 11 lb ft Fuel Rail Bolt 10 N.m 89 lb in Generator Bolt 50 N.m 37 lb ft Bracket Bolt - Front 50 N.m 37 lb ft Bracket Bolt - Side 22 N.m 16 lb ft Cable Nut 13 N.m 115 lb in Ground Cable Bolt 50 N.m 37 lb ft Heater Inlet/Outlet Pipe Assembly Bolt 10 N.m 89 lb in Ignition Coil Bolt 10 N.m 89 lb in Intake Manifold Brace Bolt - Engine Front Cover M12 65 N.m 48 lb ft Brace Bolt/Ball Stud - Intake Manifold M6 10 N.m 89 lb in Ball Stud to Cam Cover M6 5 N.m 44 lb in Sight Shield Ball Stud 10 N.m 89 lb in Tuning Valve Bolt 10 N.m 89 lb in Upper-to-Cylinder Head Bolt - Long 25 N.m 18 lb ft Upper-to-Cylinder Head Bolt - Short 25 N.m 18 lb ft Upper-to-Lower Intake Manifold Bolt 25 N.m 18 lb ft Knock Sensor Bolt 25 N.m 18 lb ft MAP Sensor Bolt 10 N.m 89 lb in Oil Drain Plug 25 N.m 18 lb ft Oil Filter Cap 25 N.m 18 lb ft Oil Filter Housing Adapter Bolt - Cylinder Head M10 58 N.m 43 lb ft Bolt - Engine Block M8 25 N.m 18 lb ft Oil Gallery Plug 31 N.m 23 lb ft Oil Level Indicator Tube Bolt 10 N.m 89 lb in Oil Pan Bolt - Block M8 25 N.m 18 lb ft Bolt - Crankshaft Rear Oil Seal Housing M6 10 N.m 89 lb in Windage Tray Bolt 10 N.m 89 lb in Oil Pressure Sender 20 N.m 15 lb ft Oil Pump Bolt 25 N.m 18 lb ft Cover Bolt 13 N.m 115 lb in Oxygen Sensor Pump Converter Pipe 40 N.m 30 lb ft PCV Tube Bracket Bolt 10 N.m 89 lb in Piston Oil Cooling Nozzle Bolt 10 N.m 89 lb in Power Steering Pump Bracket to Engine Bolt Acadia/Enclave/Outlook/Traverse; Equinox/Terrain; Vue 50 N.m 37 lb ft Bracket to Engine Bolt All Except: Acadia/Enclave/Outlook/Traverse; Equinox/Terrain; Vue 58 N.m 43 lb ft Pump to Bracket Bolt 22 N.m 16 lb ft Reservoir Bolt - Lower 25 N.m 18 lb ft Reservoir Bolt - Upper 9 N.m 80 lb in Primary Camshaft Drive Chain Left Lower Guide Bolt - Oil Pump - Second Design 25 N.m 18 lb ft Tensioner Bolt 25 N.m 18 lb ft Upper Guide Bolt 25 N.m 18 lb ft Radiator Outlet Pipe Bolt - Generator Bracket 25 N.m 18 lb ft Bolt - Right Cylinder Head Rear 58 N.m 43 lb ft Bolt - Thermostat Housing 25 N.m 18 lb ft Secondary Camshaft Drive Chain Guide Bolt 25 N.m 18 lb ft Shoe Bolt 25 N.m 18 lb ft Tensioner Bolt 25 N.m 18 lb ft Spark Plug 18 N.m 13 lb ft Starter Motor Bolt 58 N.m 43 lb ft Cable Nut 13 N.m 115 lb in Suction Tube Bolt 10 N.m 89 lb in Suction Screen Bolt 10 N.m 89 lb in Thermostat Housing Bolt 10 N.m 89 lb in Throttle Body Bolt 10 N.m 89 lb in Torque Converter Bolt 60 N.m 44 lb ft Transmission Mount Bolt to Transmission - RPO M82 60 N.m 45 lb ft Range Selector Lever Nut 9.5 N.m 84 lb in To Engine Bolt 50 N.m 37 lb ft Water Pump Bolt 10 N.m 89 lb in Pulley Bolt 10 N.m 89 lb in |
thank you
Camaro LT2 RS
Welcome.
I have PDF files on this, if you give me an email address (PM) I will send them. |
