Old 05-28-2020, 03:34 PM   #1
RupertPupkin
Drives: 2014 Camaro SS 1Le
ECS 737whp/ 635 trq
Does it look about right?
Current Mods:
• Tick Stage 3 Polluter Cam
( 233/248 | .627”/.612” | LSA113+5
• Speed Engineering LT Headers (No Cats)
• Stock H pipe
• ECS Paxton Centrifugal Supercharger 1500 (No restrictor plate)
• DSX Aux Pump
• DSX Flex Fuel
Car is ON e85/ 93
93 octane timing around 19*. And e85 is around 25*
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 05-28-2020, 03:55 PM   #2
davidscamaro
davidscamaro's Avatar
Drives: 2010 SS/RS M6 BIG cam
You are breaking up a lot after 4500rpm , belt slip or bad spark. Your tuner did not say anything? Not right to let you leave after dyno pulls like that
On the plus side your making shit ton of power, just need to fine tune some more ( mechanically and digitally )
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
davidscamaro is offline   Reply With Quote
Old 05-28-2020, 03:58 PM   #3
RupertPupkin
Cars still there. He said it could be belt slip.
730whp: 630Trq
Old 05-28-2020, 04:01 PM   #4
davidscamaro
Thats good to hear , glad you have a tuner that is not rushing to get it out and doing you right
Old 05-28-2020, 04:46 PM   #5
RupertPupkin
Seems like more can be squeezed out.
730whp: 630Trq
Old 05-28-2020, 05:00 PM   #6
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
Need to see a lot more than hp and torque numbers. Fuel pressure afr and manifold pressure at least. Definitely not right with that curve looking like that.
Greenhornet2 is offline   Reply With Quote
Old 05-28-2020, 07:11 PM   #7
Smokeynbandit
Drives: 1980 Chevy corvette
Your loosing off the low to mid range power which is hurting the torque curve needs some adjusting to gain that torque back for a better powerband. Just my opinion
Smokeynbandit is offline   Reply With Quote
Old 05-28-2020, 08:24 PM   #8
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
That’s gonna be a fun ride when you get it back and everything is cleaned up. That’s a huge jump in power
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 05-28-2020, 11:03 PM   #9
608RS
608RS's Avatar
Drives: 2015 2ss
nice numbers, i gotta see this thing!
608RS is offline   Reply With Quote
Old 05-29-2020, 04:11 PM   #10
gsxrturbo
Drives: 2010 ss
im putting down 845rwhp,but i do have a different cam,on e85,there are alot of cars running over 800 with the ecs 1500 blower setup
gsxrturbo is offline   Reply With Quote
Old 05-29-2020, 04:40 PM   #11
RupertPupkin
That’s what I’m saying.
730whp: 630Trq
Old 05-29-2020, 05:27 PM   #12
Greenhornet2
I'd datalog and talk to ted at jannetty
Old 05-29-2020, 06:47 PM   #13
RupertPupkin
Unfortunately I have no way of data logging.
730whp: 630Trq
