![]() ![]() ![]() Drives: Camaro Convertible 2014 1LT Join Date: May 2019
Black Rims
Hey everyone, I hope you are all safe. My car turned 1 on May 6th(it's a 2014) so she's one to me. I posted about this before regarding switching my silver rims to black ones. I have a yellow Convertible and the car came with silver rims. They are staggered 20x8 in front and 20x9 in rear. I have been blacking out what I can i.e badges, rear tail lights, the bow ties because I am preparing for changing the rims to black. I can go the dealer route(and even the guy on the phone laughed at the price) $475 a piece for the 5 spoke. Now I've noticed that Phastek and West Coast Camaro have sets of 4 and staggered for about a grand. I was just wondering if any of you had suggestions or a "go to" place when it comes to rims. Any suggestions would be appreciated Thanks and stay safe. Joe K.
![]() Drives: 2015 Camaro 2SS RS 1LE AGM Join Date: Oct 2013
I bought my MRRs 228 through phasetek. MRR is a very reputable aftermarket wheel company.
![]() Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '17 Corvette Grand Sport M7 Join Date: May 2012
I went with Factory Reproductions and they were terrific to deal with.
20 x 9 square ZL1 knockoff:
MY RIDE: 2017 CORVETTE GRAND SPORT--TRIPLE BLACK, 7 SPEED MANUAL, VARARAM TCR-7 INTAKE, BORLA CATLESS X-PIPE, CARBON FIBER STAGE 2 AERO, MGW SHORT-THROW SHIFTER
**SOLD**2011 TRIPLE BLACK SS CONVERTIBLE--6 SPEED MANUAL, MANY MODS, 455 RWHP/435 RWTQ DAD'S RIDE: 2012 ZL1 #1866--BLACK, 6 SPEED MANUAL, EXPOSED CF HOOD, POLISHED WHEELS, SUNROOF, ROTO-FAB INTAKE "Silly Americans, taking from the rich and giving to the poor only works in fairy tales. Success is earned here!". |
![]() ![]() Drives: 2015 Z/22 Join Date: Aug 2015
I have the same factory RS/SS wheels and painted them for much less $$
QUOTE=KillboyPowerhead;10800646]I have the same factory RS/SS wheels and painted them for much less $$
[/QUOTE]I did the same thing. At first I did Plasti dip to see if I would like it. Then I painted them and love them.
Custom TSP Stage 2 Cam/GPI intake Ported Rod Mod /VARARAM CAI/Mishimoto Catch Can/1 LE front & rear sway bars/ engine cover/fuse box custom painted, strut tower brace, Texas Speed LT, Hi Flo Cats, Magnum Tru-X pipe, NGK Spark Plugs, PCM Spark Plug Wire, Painted Calipers, CF Spoiler w/wicker bill. |
#6 |
#7 | |
Nice looking wheels. What are the weights on them? Id love black wheels myself but don't want to add 10lbs a wheel just to get it.
2013 Camaro SS/RS, Stainless Power long tube headers with HF's, Air Raid CAI, Solo Mach XL cat back, BC Racing coil overs, Elite Engineering catch can, Ferrada Forge 8 Wheels, Windows tinted at 20%, Tuned by Dyno Steve.
#8 |
![]() ![]() ![]() ![]() Drives: 2014 Ashen Gray Convertible Join Date: Apr 2017
Joe; Like you I own a 2014 rag top, mine is in Ashen Gray Metallic. I also done away with the silver wheels and now owner several sets of wheels, two sets in black. I have a beautiful set of ZL1 reproductions that are 20X10 on all four corners, with the expense of tires I like to rotate. This set of wheels is wrapped in Continental Extreme Contact DWS06 in size 275/35/20, rides and tracks beautifully.
Second set of black wheels is also a square setup, using the 2019 OEM 20X8.5 wheels wrapped in Goodyear Eagle 99Y run flats size 245/40/20 on all four corners. I am putting together a set of 20X9" R42 2014 wheels (still need 2 more 9" wheels if you know of any for sale) Once the set is complete the powder coater is going to do the set in Ashen Gray Metallic! He's going to pick up the two 9" wheels I have tomorrow morning! Those will be wrapped in 255/40/20 Pirelli Cinturato P7 tires. I also have a set of OEM 21" that I purchased new about two years ago, again square setup. Not fond of the chrome so I will sell the 21" set and find another black setup. LOVE wheels!
#9 | |
#10 |
![]() Drives: 2015 2SS A6 Commemorative Edition Join Date: Nov 2019
I bought MRR 228s through Phastek as well, in 20x10 square setup...
#11 |
USA-1
Plastidip is the easiest and most cost effective way. Just watch a few videos on it and do LOTS of light coats.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
#12 |
M017
Words of advice.. Don't ever service your car (except when under warranty) with a stealership and certainly don't buy anything from these crooks. Just installed these last week and couldn't be happier with the look and Quality. Bought rims from Phastek $1200
#13 |
I went with fake ZL1 wheels from LG Motorsports. Had them since 2015 and they have held up well. Still look new. Got them for 900$ plus tax and shiping when they were running a special. They were a sponsor not sure if they still are. Haven't seen them post in a while. Only negative, can't use a factory Chevy center cap on the LG's from what I have read. Haven't tried one. FR's can take the factory Chevy center cap.
#14 |
![]() Drives: 2014 1ss camaro Join Date: Jul 2017
I picked up a 20x9 square set up 10mm back spacing American racing wheels 922's from discount tires direct. great people to deal with. I thing I paid around 250.00 each
