Old 06-05-2020, 02:19 PM   #1
SSammy
SSammy's Avatar
Drives: 2015 2SS A6 Commemorative Edition
Direct Fit 6L80 Trans Cooler Kit?
I have a 2015 Camaro SS L99 that regularly convinces me to go with her on long spirited mountain cruises and high speed canyon runs. I have plans get a higher stall converter and cam in the future but would like some additional cooling for the 6L80 first. I’ve been practicing my google-fu and I’m having trouble finding a direct fit kit. If possible, I want a setup that doesn’t require cutting my factory lines. Are the ADM kits still available? If so, can someone let me know where I can order one from or if there’s a forum sponsor that sells them?
Thanks.
SSammy is offline   Reply With Quote
Old 06-05-2020, 02:35 PM   #2
gtstorey
ADM still has a website, just changed the name to C-8parts.com. Cooler is shown on their page.
With the correct parts cutting your factory lines isn't that big of deal. You could always get a spare set and cut those.
Old 06-05-2020, 02:52 PM   #3
SSammy
SSammy's Avatar
Thanks! I’ve installed universal coolers on some of my other vehicles and had to piece together a kit for my big block and trans swapped C10. I’ve got flare tools, tube cutters and benders, and my universal kits work very well, but if I can go with a direct-fit I’d prefer it. I appreciate the info and the quick response
Old 06-05-2020, 02:57 PM   #4
gtstorey
I installed a tru-cool by cutting the factory lines at the steel portion and used a compression to A-N fitting that was very easy and hasn't leaked a drop.
Old 06-05-2020, 03:58 PM   #5
SSammy
SSammy's Avatar
I may still end up going that route. Waiting for an email response from C-8parts, then I’ll know whether I’m gonna just hit the direct-fit easy button, piece together my own diy kit, or get a kit that is 90% and cut it in.
Old 06-05-2020, 06:44 PM   #6
SSammy
SSammy's Avatar
Do you have a part number for the kit you installed?
Old 06-08-2020, 09:02 AM   #7
gtstorey
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 06-08-2020, 09:29 PM   #8
SSammy
SSammy's Avatar
Thank you!
Old 06-09-2020, 08:43 PM   #9
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
https://www.camaro5.com/forums/showthread.php?t=568830
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
gunchamp is offline   Reply With Quote
Old 06-09-2020, 08:44 PM   #10
gunchamp
gunchamp's Avatar
Yeah it worked. Im becoming all computer smart and stuff lol. All parts needed with part numbers for the tru cool install. Plus how i did it
Old 06-11-2020, 04:04 AM   #11
Bo White
Bo White's Avatar
Instead of cutting the lines
https://www.ebay.com/p/13035774928?i...iABEgJBffD_BwE
6l80, cooling, l99, trans
