Old 12-22-2009, 09:05 PM   #1
1DERZ SS
1DERZ SS's Avatar
Drives: 2010 Camaro SS
So what size 22" tires is everyone running ?
I see alot of people running 22's over the stock 20's...and have read here and elsewhere where changing has thrown a code. So just a few Newbie questions.
1) What size tires are you running on your 22" wheels
2) Any rubbing initially ?
Thanks
Friday the 13th was a lucky day for me !
2010 Camaro SS Inferno Orange
Came home on 11/13/2009
2011 Silverado 2500 HD Crew LTZ
11/17/2010
1DERZ SS is offline   Reply With Quote
Old 12-22-2009, 09:12 PM   #2
Indpowr
Drives: Corvette C6
No codes, No rubbing
Having the right 22 makes all the difference though because weight in some companies will not be good.
We run 265/30/22 and 295/25/22
Old 12-22-2009, 09:27 PM   #3
1DERZ SS
1DERZ SS's Avatar
295/25/22 for the rears ???
11/17/2010
Old 12-22-2009, 11:19 PM   #4
71cam
71cam's Avatar
Drives: 71cam
wow...just wondering about your handling and road feel is now with the extremely low profile tires with the 22 inch rims.
You should be able to light the tires up real easy....right?
71cam is offline   Reply With Quote
Old 12-23-2009, 08:29 AM   #5
Nine Ball
Nine Ball's Avatar
Drives: 1969 & 2016 Camaro SS
On my car,
Pirelli PZero Nero
265/30-22 front
315/25-22 rear
These are the correct diameter for the 2010 Camaro. No codes if you keep the outer diameters similar to OEM.
Tony
Fquick.com/NineBall
Old 12-23-2009, 10:19 PM   #6
TaylorRyanSS
COTW: 12/13/10
TaylorRyanSS's Avatar
Drives: 1969 Camaro
Originally Posted by Nine Ball View Post
On my car,
Pirelli PZero Nero
265/30-22 front
315/25-22 rear
Tony
will 315s stick out?
Old 12-23-2009, 10:21 PM   #7
Indpowr
Drives: Corvette C6
Car rides perfect. With the H&R drop the car feels more sporty. Also, the wheels only weigh 28lbs front and 32lbs rear so they are very light.
Old 12-23-2009, 11:12 PM   #8
Nine Ball
Nine Ball's Avatar
They will not stick out at all, as long as your wheel offset is correct. Plenty of room under the '10 Camaro for a 315 tire.
Tony
Fquick.com/NineBall
Old 12-24-2009, 12:21 AM   #9
alssiri
alssiri's Avatar
Drives: 2017 ZL1 A10
Had 295/25/22 which are shorter & had them replaced by 285/30/22 Toyo Proxy 4 on the 22x9.5 wheels.
Ahmad
2017 ZL1 A10 SW (SOLD)
Whipple 2.9 with 3.2 Pulley, Weapon-X Stage 3 Cam, FIICHILLER ,LG Motorsports LT, Borla S type, ROTFAB Big Gulp, Big 3 Reservoir
Glassskinz rear window valance .
2012 ZL1 A6 (SOLD)
Forged 376 CI, LSA HeartBeat, Mast Medium Bore Heads & JDP ZLR Cam, ARH LT , MagnaFlow Resonated X + Borla Atak Catback, ADM 102mm Snout, CAI, NW102MM TB, ID850, Fore Triple Fuel Pump, MSD Wire's, Moroso CC.
Alky Control, FIICHILLER.
alssiri is offline   Reply With Quote
Old 12-24-2009, 01:43 AM   #10
TaylorRyanSS
COTW: 12/13/10
Drives: 1969 Camaro
Tony
ok thanks... so would a 315 fit on a 22x10.5 - 5/120 pattern - 35 offset?
Old 12-24-2009, 07:53 AM   #11
khislop007
ZEUSS
khislop007's Avatar
Drives: Hard!
Now those 315's look nice and wide! I might go with the 265/35/22 and 315/30/22 just for a little more sidewall meat!
On my car,
Pirelli PZero Nero
265/30-22 front
315/25-22 rear
Tony
Old 12-24-2009, 08:14 AM   #12
PatrickfromMD
PatrickfromMD's Avatar
Drives: Buick Enclave/Corvette/2010 Camaro
On my car,
Pirelli PZero Nero
265/30-22 front
315/25-22 rear
Tony
Tony,
Very good information. What’s your experience been with such a low sidewall height? I’ve been worried about potholes bending rims.
I would have like to consider a 21 inch wheel, but I don’t see anyone with a 305 or 315 in that diameter. Thoughts? Also, what’s your thoughts on 22 rear, but 21 front? I seem to recall the Camaro concept had different diameter front/rear
I plan to purchase a wheel tire combo this spring
***56K miles and still going strong***
2SS/RS IOM ext w/cyber grey stripes, tinted windows, IO int Auto
ProTorque prototype Converter, Chuck Mosello of Westchester Corvettes Custom Tune
T&T installed SLP Longtubes, Powerflow X Pipe, and Powerflow axle back
JL 10W3 in custom side sub box, new door tweeters, Alpine 5ch 600 watt
T&T configured ACS front Fascia w/ heritage grill, splitter, dual color halos, , led markers, taillight bezels , all accented in CGM
Gary Custom Z vented fenders. Vararam ver 2
PatrickfromMD is offline   Reply With Quote
Old 12-24-2009, 08:21 AM   #13
khislop007
ZEUSS
khislop007's Avatar
Drives: Hard!
Originally Posted by PatrickfromMD View Post
Tony,
I feel the same way about the 21's. I have searched and searched but all I see in 21's are 295's and 325's. That's why I might go with a slightly thicker sidewall for the 22's. It's not much of a difference in height but I might have to recalibrate the speedo, but that's ok.
Old 12-24-2009, 10:10 AM   #14
Nine Ball
Nine Ball's Avatar
Tony,
21" is the bastard wheel size. Tire manufacturers offer a plethora of sizes in 20" and 22", but not the oddball 21". This was the same way with 19" wheels for a long time, with 17s and 18s getting all the tire selection.
The sidewall height on the 22" wheel and OEM tire diameter is equivalent to the sidewall height of a 19" wheel in a typical 26" tall tire. So, if you saw 19s on a 4th gen or a Corvette, the sidewalls would be the same as the Camaro rolling on 22s with its 28.6" tall tire. Here is a photo to help illustrate how tall the Camaro tires are. Pictured below are the OEM Camaro wheel, next to an 18" Z06 front wheel, next to a 17" Firehawk wheel.
Notice how tall the Camaro tire is? That means you can run a bigger diameter wheel and still have enough sidewall. Here is another funny photo, comparing an 18" wheel (with 26" tire) to the Camaro wheel. On the second photo, I photoshopped the 18" wheel into the Camaro tire, to illustrate how much sidewall there would be if an 18" wheel was using a Camaro tire height.
Fquick.com/NineBall
22" TSW wheels with tires now available starting at $ 2668.00 shipped Speed Depot Wheels / Tires 25 04-05-2010 10:58 AM
Found Specs for 2LT Factory 19" Tires ... dougmac Wheels and Tires Talk Sponsored by The Tire Rack 0 04-05-2009 06:12 PM
Will the SS have 20" run flat tires? Can we go bigger in size? Hoss Wheels and Tires Talk Sponsored by The Tire Rack 18 11-28-2008 11:59 PM
