Old 06-09-2020, 08:00 PM   #1
ShockZL1
Drives: 2020 Chevy Camaro ZL1 M6
Exclamation 2020 ZL1 Flex Fuel Question
Hey guys, I am the proud owner of a 2020 Shock Yellow ZL1 M6. I bought the Advance Fuel Dynamics Flex Fuel kit and ran into an issue. When you pull up Youtube Install videos, everyone references Pin38 to plug the wire from the Flex Fuel Sensor into the harness of the ECM. I guess there is "supposed" to be a gray plug that you remove in order to seat the wire. My harness only has 1 gray plug in Pin54. Pin38 is open(no wire seated) but no pass-through for the sensor wire to plug into the harness. Has anybody else had this issue? I ordered my car in December of 2019, it was built in January of 2020 and I took delivery in February of 2020. Can I just plug the flex fuel sensor wire into Pin54 after removing the gray plug? Any help is much appreciated.
ShockZL1 is offline   Reply With Quote
Old 06-09-2020, 09:22 PM   #2
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
Wrong forum, try the 6th gen forum.
ZMEnow is offline   Reply With Quote
Old 06-10-2020, 05:48 AM   #3
'10CamaroDude
Drives: 2010 Camaro LS
Stock, you can E50, but that's usually E85 winter fuel mix.
The 2020s are different, just push the black stopper through on pin 38. There is a video that
shows it. https://youtu.be/LIq2F02yOKE?t=620
@10:20
His, shows a stopper there, you push that through, then put the tap in.
'10CamaroDude is offline   Reply With Quote
e85, flex fuel, zl1
