06-10-2020, 07:42 PM | #1 |
Drives: 2011 Camaro 2LT Join Date: May 2012
What is this engine component?
Anyone know what is this? The metal part like a can.
06-11-2020, 04:22 AM | #2 |
Drives: 2010 SS Camaro Join Date: Oct 2008
I'm no expert on the v6 but it looks like it could be the filter drier for the A/C
06-11-2020, 04:32 AM | #3 |
Drives: 2011 Camaro 2LT/RS Join Date: May 2015
it's the auxiliary vacuum pump for the brake booster
06-11-2020, 04:45 AM | #4 |
Vacuum pump for your brakes.
Not all of them have it either, I have seen some models without the booster pump. My hard line was broken, and hidden under that rubber insulation, and I still had brakes, so mine probably doesn't work. Since the line was replaced, I do not have power brakes in initial cold hi-idle. Once the idle comes down, they work fine, and from then on once warmed up. |
