NightFuryCamaro
Drives: 2012 Camaro 2SS Join Date: Aug 2019
What kind of power is safe with stock transmission and rear?
My build is coming along very nicely as of lately. I just added a McLeod RXT Clutch kit that came with a billett steel flywheel and a twin disc clutch good for 1000 ft-lbs. Also threw in an MGW short throw shifter while I was in there, and I am loving it, much better than factory Hurst shifter. Currently running a BTR Stage 4 Supercharger Cam kit and full Bolt-Ons. I'm pushing about 470 to the wheels, 535ish Crank. I plan to get a whipple 2.9L supercharger in the near future. I'm wondering where that will put me in terms of horsepower, interested in both crank and wheel numbers, and what else I should plan on replacing if need be. I dont like 1 piece rears, I want to stay independent (if I need to do the rear). I'm also thinking about turning up the boost to about 11 psi after the blower is on. I heard Strange makes good rears, the one I saw recently also came with 3.73 gears. Any advice?
Follow me on Instagram and TikTok! @NightFuryCamaro
https://www.instagram.com/nightfurycamaro/ https://www.tiktok.com/@nightfurycamaro |
![]() Drives: 2013 1ss Join Date: Jul 2012
As a reference, I have a whipple 2.9 on a stock 2013 ss ls3 and it dyno 610rwhp after the tune. The only other items to add power were fresh air scoop and chai, and long tube headers with high flow cats. It's running the 4 inch pulley on 93 octane.
As far as the suspension, it will depend on how you use it and how well the tires hook. While on the stock tires I had no drivetrain issues. Add slicks and damaged just about everything. |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
You'll be about where i am power wise. You'll need fuel system upgrades. Drag racing at the track with slicks and you'll break stuff inevitably. Though if you upgrade the rear suspension, get rid of about wheel hop, and preload the drivetrain the stock stuff will hold up pretty good. Upgrade would be ZL1 diff. Axles and ds stock will work. Trans, I'd upgrade to a tick rebuild with cryogenic treatment. That's what i'm going to do when my clutch goes along with an mgw shifter. Rear railing arms, toe links, cradle mounts are a must for wheel hop.
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
I like the OP’s original question. I suspect there are no definitive answers, simply because what’s being modded and how it’s used. Cool to hear some of the real life stories of what lives and what doesn’t.
old school chevy rodder
Drives: 2021 zl1 a-10 WildCherry Join Date: Jul 2012
https://www.hotrod.com/articles/hrdp...parts-failure/
Good Old article.....its still very relevant...…….about what breaks on our Camaros, I recommend BMR toes and trailing arms and a good LPW rear cover.....good luck
#6 |
![]() ![]() Drives: 2011 2SS/RS Victory Red Join Date: Aug 2011
I couldn't drive out of the neighborhood without losing a rear axle CV once I passed 500. It is lowered on coil-overs, but there is no factory suspension left (all BMR or UMI). GForce outlaw 1500hp axles solved the issue. The Hurst wheels are heavy and were probably a contributing factor.
Updates: BTR Stage 2 VVT Cam Kit w/Smith Brothers Trunnions, Fluidampr, RX catch can, B&M Trans pan mod, Kooks Black Headers, Borla S-tunes, Eibach Multi-Pro-R2 coilovers and Swaybars, BMR Full Bushing kit with Toe and Trailing arms, RB Rotors w/EBC Pads, GForce 1400 Axles (now on order). AVH-X5800BHS in Scosche GM5201AB. |
#7 | |
#8 |
The cv angles suffer when lowering and not doing offset diff bushings. That could be a big part of the problem richards
#9 | |
![]() ![]() ![]() ![]() ![]() Drives: 2014 Camaro ZL1 Join Date: Jul 2019
Pros: Looks good, maybe handles better if setup right Cons: Cost $$$ Magnetic ride needs recalibrated harder to get over driveways and curbs harder on some components like CV dealing with jacking, lifting and road conditions. Ugh!
#10 |
Stigs Bahraini Cousin
Drives: 2015 Camaro 2SS 1LE Join Date: Oct 2018
My 2010 did 700+ with stock tranny and diff though it wasn't beat on.
2015 CAMARO 1LE
#11 |
LSx FTW!!!
Drives: 2010 Camaro 2SS RS Join Date: Jan 2017
I've been at 760 rwhp on stock diff and axles for like 2 years.
BUT.... I keep TC on and no sticky tires yet. I run Continental DWS 06's. The sidewalls are tearing up on them though.
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X Circle D 3400 Triple Disc Kooks Jet Hot Headers Kooks Full 3in exhaust Trick Flow GenX 255's Polished PAC .660's & Ti-retainers TSP VVT 3.2 cam kit w/DoD Delete Smith Bro's Trunnion kit AEM X-Series OBDII Widebands FIC ID1300x Injectors GM ZL1 High Output Fuel Pump DSX Tuning Flex Sensor DSX Auxiliary Fuel System Tim King Stage 4 Max Effort CTSV 6L90 DSS 1 piece aluminum driveshaft JRE 6L80E / 6L90E Dipstick NGK Iridium IX spark plugs #7 heat range Mighty Mouse Camaro 5 Wild w/-12an and Billet Black HP Tuners VCM Suite |
#12 |
GPI Sales Consultant
Drives: 2011 Camaro 2SS SGM Join Date: Jul 2016
Stick car drive-line life his highly dependent on how it is driven. Plenty of stories go both ways - guys breaking axles and diffs on bolt on power and OE traction, guys making 700whp+ in a tire and keeping the stock stuff alive for years. The biggest variable is without a doubt the left (and right, to a lesser extent) foot of the driver.
These cars seem to be willing to handle a pretty good amount of steady state load, but are not very tolerant of shocks to the drive line. The stock clutch is quite a strong unit, and has more than enough torque capacity to snap the factory axles and any ring and pinion you put out back in the stock housing. The key to keeping that stuff alive is no clutch dumps, and no wheel hop. Either one of those are a quick ticket to forced upgrades. I've broken a few diffs and axles in my car on the road to learning what works and what doesn't. For me, I've found a couple things. First - you need upgraded subframe and diff bushings. The factory pieces are like big springs that live to put oscillation into the driveline, which turns into wheel hop. For suspension upgrades, those are top of the list without a doubt. The rest of the stock stuff leaves some to be desired, but doesn't contribute near as much to hop as those two pieces. Second, you can beef up the rear end by running a quality gear (Motive, US Gear, Yukon), properly setup, and with a diff cover to give the case some rigidity, and the ring gear caps some extra support. That setup is a bit like putting a stethoscope right on the ring gear and piping it into the cabin, so some gear noise would be expected. But the biggest thing you can do is drive it better. If the car ever gets into wheel hop, get out of the throttle, immediately. When you launch, don't dump the clutch, make a quick but deliberate release that doesn't "surprise" the driveline. I'm a big fan of preload, when I launch I use the e-brake to hold the car, and get the clutch dragging just the tiniest bit, to take slack out of the driveline to remove any "snapping" effect. This has an added benefit of helping control wheelhop as you've already "wound up" the spring like effect of all those mounts, bushings, arms, etc so you're less likely to get them rapidly springing back at you, inducing hop.
Got a question about a GPI product? Feel free to shoot me a message! |
| Tags |
| power numbers, rear, transmission, whipple, whipple 2.9 |
