Old 06-12-2020, 12:30 PM   #1
Mark_Z28
Drives: Black 2015 Z28 #457
TPMS issue FL reading zero
So I'm having my first issue, its possibly a bad TPMS sensor. The FL is just reading zero on the dash display even though its holding air without issue. Anyone else have a TPMS just read zero?
Mark_Z28 is offline   Reply With Quote
Old 06-12-2020, 12:59 PM   #2
AustexaSS
Build Date - Dec 08, 2014
AustexaSS's Avatar
Drives: 2015 Z/28, #1007, Black A/C Stereo
Yes, I have one go bad previously, reading 0 and it required replacement. Prior to replacing, you might try to reset all the sensors so see if this could clear up the issue. Most sensors should last at least 5 years, I have gotten more than 10 years of life out of some. I have also run into an issue on another Chevrolet vehicle I own after replacing the same sensor 2x to have it stop working within hours and giving up on it thinking I bought bad parts, to days later have the vehicle battery die. Vehicle batteries seem to die / deteriorate more often in the hot summer months. I replaced the vehicle battery and the single TPMS that was not reading resumed normal operation. Strange, I know, never heard of that one before either but it has been working for over a year without fault.
AustexaSS is offline   Reply With Quote
Old 06-12-2020, 02:44 PM   #3
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
This spring when taking the car out of storage, and after rotating the tires and resetting the TPMS with my trigger tool, the right front of my car started reading zero. Tried another reset and trigger and it's been working perfectly since.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 06-12-2020, 03:10 PM   #4
Shoupaloop
Drives: 2015 Z28
I had one that slowly dropped the reading. It never got to zero, but it would trigger the dash light in the mid 20's IIRC. The tire actually had correct pressure in it, but the sensor was reading lower and lower. I didn't have to replace it.
Shoupaloop is offline   Reply With Quote
Old 06-12-2020, 03:55 PM   #5
'10CamaroDude
Drives: 2010 Camaro LS
One of mine (Rear Left) stops transmitting when it gets over 38 PSI in the heat...
If it rains, the tire temp lowers, and it starts transmitting again.
'10CamaroDude is offline   Reply With Quote
Old 03-31-2021, 06:41 PM   #6
232_ray
Drives: 2013 ZL1 / 1969 Z/28 camaro
Anyone have a correct part number for the TPMS sensor? Dealers won’t give it out anymore.
232_ray is offline   Reply With Quote
Old 03-31-2021, 06:56 PM   #7
HoodCheck
HoodCheck's Avatar
Drives: 2018 ZLE (M6/hyper blue)
Part #s can be found here:
https://www.gmpartsdirect.com/v-2014...tor-components
The part # for the sensor is 13598772
https://www.gmpartsdirect.com/oem-pa...Y4LWdhcw%3D%3D
Don't order from gmpartsdirect unless you have 1-12 months to wait around though.....ebay will have them...
HoodCheck is offline   Reply With Quote
Old 03-31-2021, 10:22 PM   #8
RaycinSS
RaycinSS's Avatar
Drives: 2015 Camaro Z/28
AustexaSS is right on the money. I've had this happen a couple times before and did a reset on all 4 with a tpms relearn tool I bought and it got it working again both times so I'd try resetting them first before spending any more money. I highly recommend picking up a relearn tool to keep in the glovebox or trunk.
RaycinSS is offline   Reply With Quote
Old 04-01-2021, 01:52 PM   #9
MIKZ28
Drives: 2019 Camaro ZL1 2004 Pontiac GTO
THE CORRECT PART NUMBER IS 13581560. THE 14 15 Z/28 USES THE CORVETTE TPMS SENSOR. HEAVY DUTY STEEL TUBE AND CAP.
MIKZ28 is offline   Reply With Quote
Old 04-01-2021, 03:01 PM   #10
232_ray
Thank you.
Old 04-01-2021, 03:24 PM   #11
SIM GhostrdrZ
SIM GhostrdrZ's Avatar
Drives: ‘14 ZL1 M6 vert
I believe ours are 315 MHz sensor, not the 433 MHz?
Some of those p/n are showing 433 MHz, I’m not sure if they all are.
SIM GhostrdrZ is offline   Reply With Quote
Old 04-01-2021, 03:31 PM   #12
HoodCheck
HoodCheck's Avatar
It looks like they have the wrong part # listed up there. It says its for a Z/28 too, but I looked up that part number, and sure enough, it looks like the rubber stemmed version. Ironically, gmpartsdirect has what looks to be the correct TPMS sensor for our cars shown in the 3rd image lol.
Good catch.
Old 04-01-2021, 06:40 PM   #13
72 Z27
Drives: '70 Z28/RS & '14 Z28
AC Delco 20964159 is what I bought and installed 3 months ago. They matched the original TPM Sensors that came where already the car. They worked fine with the re-learn process.
Jeff
72 Z27 is offline   Reply With Quote
Old 09-05-2021, 08:20 PM   #14
Gbland60
Gbland60's Avatar
Drives: 2015 z28 Black w/ac #645
Thanks guys for the info on part #’s Just had one go bad tonight left rear
Gbland60 is offline   Reply With Quote
