Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > Forced Induction
Old 06-13-2020, 04:23 PM   #1
Tarendor
Tarendor's Avatar
Drives: 2012 camaro 2ss rs L99
ZL1 fpcm for sale (sold)
$25.00 shipped in lower 48.
I bought a ZL1 fpcm for my turbo project and don't need it so hit me up if you do.
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
Tarendor is offline   Reply With Quote
Old 06-16-2020, 10:07 AM   #2
Tarendor
Tarendor's Avatar
ttt
Old 06-16-2020, 10:07 PM   #3
snake309
Drives: 2011 Camaro SS, 1985 Iroc Camaro
PM Sent
snake309 is offline   Reply With Quote
Old 06-19-2020, 10:01 PM   #4
Tarendor
Tarendor's Avatar
Still for sale
Old 06-20-2020, 11:23 AM   #5
JaysSS
JaysSS's Avatar
Drives: 2010 Camaro 2SS RS
Can the SS FPCM drive the ZL1 fuel pump w/ tune or is the ZL1 FPCM needed to run the ZL1 fuel pump?
JaysSS is offline   Reply With Quote
Old 06-20-2020, 12:45 PM   #6
Tarendor
Tarendor's Avatar
A ss fpcm can run a zl1 pump but the zl1 pump would be limited by the voltage restrictions and limitations of the ss fpcm.
Do you have hptuners?
Old 06-20-2020, 01:02 PM   #7
JaysSS
JaysSS's Avatar
Yes, I have HP Tuners. Ill send PM
