Old 06-14-2020, 07:39 AM   #1
wfolarry
Drives: 2010 Silver V6/M6
Excessive oil consumption lawsuit
I was reading elsewhere that GM was settling some excessive oil consumption lawsuits for the 4 cylinder & the 5.3. Everything I read said they extended warranties on other models with the v6 but the Camaro was excluded. Anyone know if there is any litigation going on? It seems it's a well known problem but if it's in a Camaro too bad. I read the CTS was extended to 120,000 for issues such as the timing chain. I have a 2010 with the v6 that runs great. No leaks. Drinks oil like a drunken sailor though. It would be nice if they did something to make this right.
wfolarry is offline   Reply With Quote
Old 06-14-2020, 02:33 PM   #2
'10CamaroDude
Drives: 2010 Camaro LS
There is a FIX for the 3.6 engines, a new valve cover gasket:
Go to 2:32
'10CamaroDude is offline   Reply With Quote
Old 06-14-2020, 06:05 PM   #3
wfolarry
Can it be that simple? Gaskets are cheap. I'll give it a try. Get a new PCV valve too while I have it apart. If it helps at all I'll be happy.
I was told by a friend of mine that has his own auto repair business that it was the rings. Same thing with the 5.3's.
Old 06-15-2020, 02:36 AM   #4
'10CamaroDude
You won't need a new PCV, just clean it. It does not have a spring and check-ball,
just two holes in the bottom, and one at the top. If you are 2010 to early 2013, then
update the part with drilling. Two bottom holes to 5/64th, and the top to 7/64th. You
can pull it out of the valve cover to clean it, and update it if needed.
https://youtu.be/yL0DIBV1hck
https://youtu.be/8ohm2rOtBb4
https://youtu.be/wCV1KMrX4uI
As far as it being that simple? Well, GM updated the part for that reason.
Old 06-22-2020, 04:47 PM   #5
wfolarry
would you happen to know the part#? I'll just order it online from GM parts direct.
Old 06-23-2020, 05:22 AM   #6
'10CamaroDude
Part# I found was 151041701 on eBay
It's the KIT, with both sides, and the plug valley seals.
Gasket Kit - GM (12691205) Replaces: 12647148
This has ALL the gaskets, and the picture shows the new style
RH side gasket.
There is a timing cover gasket update too:
12622550 Engine Timing Cover Gasket Replaced by Part Number 12691259
Old 06-28-2020, 09:08 AM   #7
ForgotUsername
Drives: 2010 Camaro RS LT2
I can attest to this, the gasket design was updated.
I replaced my valve covers entirely, since I wasn't sure if other parts of the design changed as well. It also included a new PCV barb. You might be okay just getting the updated gaskets and cleaning your old PCV barb. See attached images.
I noticed a reduction in oil being used, however it still uses/burns a bit less than one quart between oil changes.
Some notes:
-There's RTV where the timing cover mates with the head. Clean and reapply fresh little dabs of RTV when you have this apart.
-The spark plug tubes will be tight to the new gaskets on the new valve covers. Put a bit of oil on the spark plug tube gaskets (Haynes service manual recommended this).
ForgotUsername is offline   Reply With Quote
Old 06-29-2020, 01:40 AM   #8
'10CamaroDude
Thanks for the pictures, that's neat.
Yeah, the driver side is the clean air side, so that would look lighter on that side. Most
of the oil vapor is on the passenger side.
Wonder why there is no metal piece on the passenger side VC top.
That's one job I am NOT looking forward too...
Old 07-06-2020, 09:01 AM   #9
GhostOutlaw
Drives: Black 2011 2LT/RS
What? GM settling another issue with the V6 engines and NOT including the camaro in the warranty/repairs? Color me surprised.
GhostOutlaw is offline   Reply With Quote
Old 09-02-2020, 07:35 AM   #10
Guro305
Guro305's Avatar
Drives: 2010 LS Victory Red
I guess my only real question is if you haven't already and if you are one of the lucky ones who hasn't had the issue yet, will this same your timing chains?
Guro [Filipino/Tagalog (goo-roh) nee~guro} noun. An expert/master. Implies not only wizard skill but also a history of being a knowledge resource for others.
-Fifthgen Chevy Camaro Victory Red-
-C4 Chevy Corvette White-
Guro305 is offline   Reply With Quote
