06-15-2020, 09:59 PM | #1 |
Drives: 2020 Camaro Join Date: Jan 2020
Slight mistake for key o~o
So I was going to do the install for my new throttle body but required the negative battery to be unplugged for at least 8 hours and leave trunk open. So I did and wanted to make sure my manual key worked to get inside my car.
Well, it did but I guess I put the cap on wrong and it does not wanna pull off nor does it wanna click in place. I plugged the battery back in and I can still enter and exit but I need to access my car if i do the install. Now my small question is how do I fix that mistake i made ^^;; |
06-15-2020, 10:20 PM | #2 |
Drives: 2018 Camaro V6/RS Join Date: Nov 2018
Why do you have to leave the battery disconnect for 8 hours?
06-15-2020, 10:23 PM | #3 |
It was option C) but I cant get the cap to snap back in place or take it off. Considering I never did something like this, I didnt wanna mess up my car so I went with the safest option
Throttle body is from Soler Performance. |
06-15-2020, 10:53 PM | #4 |
Drives: 18 zl1 Join Date: Aug 2017
I left mine disconnected for about an hour. when installing the soler t/b and the cai, I went and ate lunch and came back and it was done. no problems.
06-15-2020, 11:05 PM | #5 |
I need help with my manual key cover. It wont pop back in.
06-15-2020, 11:09 PM | #6 |
06-15-2020, 11:27 PM | #7 |
This cover right here. I guess I put it in wrong but its fighting me.
06-16-2020, 12:27 AM | #8 |
Long hauler
Take it off the same way you did before, I did the same and just took it off and reseated it
2022 2SS 1LE - Window Sticker - Cold Air Inductions Elite Carbon CAI
2016 1LT v6 - Totaled Happiness: Infinite |
06-16-2020, 12:39 AM | #9 |
06-16-2020, 04:31 AM | #10 |
Drives: 08 Tiburon GS, 2018 Camaro 2.0T Join Date: Sep 2017
I guess you'll have to pry it gently. Use something to protect the door and then pry it slowly. These plastic parts are strong,it should not break.
2018 Camaro LS | 6 spd | 2.0L turbo | Nightfall Grey | RS package | Technology Package.
--------------------- Order WDGHKX 1100 - 5/08/2018 | 3800 - 6/18/2018 2000 - 5/09/2018 | 4200 - 6/21/2018 3000 - 5/28/2018 | 5000 - 6/27/2018 6000 - 6/29/2018 |
06-16-2020, 06:25 AM | #11 |
Drives: 2017 HBM 2LT RS Convertible V6 A8 Join Date: Jan 2018
Here's what the back of the cover looks like. The extended piece on the left is the clip to keep it in place.
I see part of your cover is over the rubber gasket at an angle. It looks like yours is cocked sideways a little and that may be acting to lock it in place. If you pry from the bottom slot, that may lock it in further since it is already angled in that direction. Maybe you can twist it back straight first before trying to get it off. Hope this helps. |
06-16-2020, 06:51 AM | #12 |
Drives: 2018 2SS Coupe A8 Join Date: Nov 2016
Had this happen to me once
Took a helpful body shop employee at the dealership 30 minutes to figure out so don't feel bad. Above advice is good. My cover wound up scratched, repaired with touch up paint kit. Funny now but aggravating and humiliating at the time. When ready to reinstall follow instructions in owners manual in exact order. If memory serves me correctly we got it off, put it on wrong a second time, then read the manual. Easy to make this mistake 😉
Jeff |
06-16-2020, 07:45 AM | #13 |
Drives: like an old lady Join Date: Jun 2012
lucky. i left some headers alone by the car for 2 weeks and they never installed themselves.
2016+ camaro: everyone’s first car
06-16-2020, 08:46 AM | #14 | |
Coupe Newbie
Drives: 2017 ZL1, 2021 Corvette Convertible Join Date: Jul 2011
The trick is to slide the cap on from the side while holding the door handle open. The GM engineer that came up with that procedure to reinstall the cap should be flogged!
