Old 06-17-2020, 07:24 PM   #1
c10man
Drives: 1986 c10. 2008 Z06
WTB LS3 CAM ASAP
Hey guys, im in need of a cam quickly, I had a custom grind on the way and it was lost in shipment... 3-4 weeks for a new one which will not work. The cam specs were 227/235 .619/.614 111 LSA. My heads were just decked and was ready to put everything back together... until this happened.
Please let me know what you have, I would be looking into overnight shipping as I need to get the car out of my buddy's garage.
Thanks!
c10man is offline   Reply With Quote
Old 06-17-2020, 08:16 PM   #2
Quicksilver-SS
Quicksilver-SS's Avatar
Drives: 2014 1SS / RS M6
I have a stock LS3 Cam, Raleigh NC 55,000 miles
Quicksilver-SS is offline   Reply With Quote
Old 06-17-2020, 08:23 PM   #3
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
I have a tsp stage 4
235/239 .627/.624
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 06-17-2020, 10:40 PM   #4
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
Installed but never run.
Sent from my Pixel XL using Tapatalk
Old 06-19-2020, 10:59 AM   #5
c10man
235/239 .627/.624
Thanks, but I milled the heads 0.035 so i dont think a cam that size is going to work without fly cutting the pistons... probably should have put that in the description sorry.
Old 06-19-2020, 11:00 AM   #6
c10man
I still have my stock cam as well, but my installer threw away all of my one bolt timing gear and I already have the 3 bolt stuff, so im looking to go ahead and upgrade. Thanks!
Old 06-19-2020, 11:53 AM   #7
gtstorey
Isn't the LS3 cam 3 bolt and the L99 one bolt?
Old 06-19-2020, 05:37 PM   #8
Bo White
Bo White's Avatar
No
cam, camshaft
