Old 06-18-2020, 12:38 PM   #1
Cavalo Preto
Cavalo Preto's Avatar
Drives: 2011 ss2 convert
Engine oil
Hey everyone
What oil is everyone using with the supercharged engines ?
I have Maggie 2300 with a blower cam
Cavalo Preto is offline   Reply With Quote
Old 06-19-2020, 07:45 AM   #2
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
I have 5w-30 mobil in mine. Key to oil is change it when it's dirty, you'll get a million different answers on what to run.
Greenhornet2 is offline   Reply With Quote
Old 06-19-2020, 10:05 AM   #3
Vegas Bound
Drives: 2013 Sparkly Red One
I run Mobil1 15w50 but I don't have the LS3 in the car any more.
Vegas Bound is offline   Reply With Quote
Old 06-19-2020, 10:24 AM   #4
racesloth
Dan
Drives: 2010 Camaro 2SS IOM
Mobil1 5w-30 with and once of zddp added.
Dan
2010 IOM SS
YSI-B, Pat G Cam, Ported CTS-V Heads, ARH LTs MBRP 3" exhaust
http://www.camaro5.com/forums/showth...&highlight=ysi
racesloth is offline   Reply With Quote
Old 06-19-2020, 02:01 PM   #5
Axe55
Drives: 2012 Camaro SS
Royal Purple 5W-30.
2012 Camaro SS LS3, JRE Scoop, CAI intake, Whipple Supercharger, Fast 85lb injectors, ZL1 pump, McLeod RXT clutch, MGW shifter, Stainless Power 1 7/8 headers w/HFC, Ridetech coilovers, BMR sway bars, trailing arms, toe rods, cradle bushing inserts, 2020 Speed Tuned.
Axe55 is offline   Reply With Quote
Old 06-19-2020, 04:23 PM   #6
dan0617
dan0617's Avatar
Drives: 2011 Inferno Orange SS Convertible
This. I use the Mobil1 5W30 and add half a bottle of Comp Cams break in oil additive.
2011 SS IOM Vert. ECS Vortech 13+ psi, Water/Meth, ID850’s, ZL1 pump with MSD Voltage Booster, 2800 stall, LT headers, Drag radials, Drag alignment, Cradle Bushings. A million other supporting mods. Tuned by Ted.
dan0617 is offline   Reply With Quote
Old 06-19-2020, 07:15 PM   #7
Big Biscuits
Big Biscuits's Avatar
Drives: 2010 1SS LS3
Amsoil 10/30. Thinking about running rotella 15/40 with the current FI. Hell, most built motors run 20/50. I have ran 15/40 in lq4 and up 6.0 trucks for years with zero issues. Like said before you will get 100 different opinions.
2010 CGM 1SS
408/4L80E/ZL1
Vortech V-13 94C
Big Biscuits is offline   Reply With Quote
Old 06-19-2020, 10:14 PM   #8
'10CamaroDude
Drives: 2010 Camaro LS
If you're gonna use ZDDP you may as well use Rotella or Delo400 Diesel
motor oil. They're both 5W40s, and Mobile 1 has a 5W40 diesel motor oil
as well.
'10CamaroDude is offline   Reply With Quote
Old 06-20-2020, 11:22 AM   #9
RedTexasSS
Drives: 2012 SS Red w/ black rally stripes
Driven Racing Oil " LS 30 " 5W30 by Joe Gibbs racing.
2012 SS Camaro, Victory Red w/black rally stripes, SLP front splitter, ZL1 Rocker panels, ZL1 Add-ons Stealth Wickerbill, L99, Magnuson Heartbeat supercharger, 65 lb. injectors, 87 mm pulley, ZL1 fuel pump, ADM FPCM,1 7/8 Texas Speed long tube headers, v-max ported throttle body, Rotofab cold air intake with Apex scoop, Apex catch can, MSD plug wires, AEM AFR and Boost gauges, GPI SS1 VVT Cam, HP tuners with remote tune by Ryan at GPI, Solo axleback exhaust w/j pipes and stock resonator.
RedTexasSS is offline   Reply With Quote
Old 06-20-2020, 12:19 PM   #10
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
This has more to do with the designed clearances in the rotating assembly than anything else. Stock bottom end= 5w30; built motor= whatever you or the builder designed it to run...
I'm using Redline 5w30 in mine, FWIW.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp // CSP LT's & Ultra Cats // BMR MM // BC Forged KL13
Mods being installed-
oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc.
RobZL1 is offline   Reply With Quote
Old 06-20-2020, 02:41 PM   #11
Vegas Bound
That is exactly why I run 15w50. Builder said to.
Old 06-21-2020, 09:00 AM   #12
eLeSthree
Drives: 2011 Camaro SS 6sp
Yea i stayed with mobile 1 for the stock ls3 and it served me well. Changed it more often than needed. That motor was sold and put into a c5 roadcourse setup.
Thompson recommends Valvoline VR1 20/50 for the dart 427. So thats what it will get for life.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 06-21-2020, 05:24 PM   #13
cornfield camaro
Drives: 2011 l99
oil
This what i run.
cornfield camaro is offline   Reply With Quote
