Old 06-25-2020, 06:00 PM   #1
Maroon 6.2L SS
Maroon 6.2L SS's Avatar
Drives: 2010 Camaro SS A6
Dragrace with no A/C belt?
Hey all. I've had my A/C belt come off/shred etc...twice over the last couple of years. I only do bracket racing on Sundays from spring thru fall. Can I do without this belt? I'm not concerned with having A/C. Will having it off cause me any problems?
Thx
Maroon 6.2L SS is offline   Reply With Quote
Old 06-25-2020, 06:05 PM   #2
Vegas Bound
Drives: 2013 Sparkly Red One
I'd pull the fuse so you don't accidentally turn it on. It may damage the compressor.
Vegas Bound is offline   Reply With Quote
Old 06-25-2020, 06:21 PM   #3
Maroon 6.2L SS
Will do, thanks Vegas
Old 06-25-2020, 08:47 PM   #4
lemontwist
lemontwist's Avatar
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled
it is really a waste of time.it will not make any difference at all on your times. i am willing to bet ac not running on a dyno or no ac belt = the same HP
lemontwist is offline   Reply With Quote
Old 06-25-2020, 09:18 PM   #5
Vegas Bound
That's not the issue. Often, the belt gets thrown and wraps the balancer and damages the oil seal. That is a PITA to replace.
Old 06-25-2020, 11:21 PM   #6
lemontwist
lemontwist's Avatar
i didn't know that was a issue
Old 06-25-2020, 11:50 PM   #7
Vegas Bound
If you raced, you'd know.
Old 06-26-2020, 12:00 AM   #8
'10CamaroDude
Drives: 2010 Camaro LS
You won't have a water pump without the belt, unless you put in an electric one.
That's why it's called a serpentine belt, it drives all the accessories.
'10CamaroDude is offline   Reply With Quote
Old 06-26-2020, 12:03 AM   #9
Vegas Bound
LOL.
:l aughabove::bon k:
Old 06-26-2020, 08:04 AM   #10
gtstorey
On the V8, the AC is it's own separate belt.
Old 06-26-2020, 12:18 PM   #11
Vegas Bound
And if Dude had a V8, he'd know that.
Old 06-26-2020, 12:20 PM   #12
RankSS
Better to Remain Silent and Be Thought a Fool than to Speak and Remove All Doubt
2010 Camaro SS RS, Maggie with 3.4" pulley, 60# injectors, ADM dual fuel pumps, ADM Stage 2 Cam with Brian Tooley springs and pushrods, black CAI intake, Stainless Works long tube headers w/gutted cats, ZL1 Diff w/offset bushings, Pfadt lowering springs, Pfadt sway bars, Pfadt solid sub frame mounts, BMR trailing arms and toe rods, Hurst short throw shifter, Painted on Hugger Orange stripes, Forgestar F14 Piano Black wheels, Nitto NT05 rubber.
RankSS is offline   Reply With Quote
Old 06-26-2020, 03:36 PM   #13
Maroon 6.2L SS
Hey Vegas. That's pretty much exactly what happened to me. When I went to go do something in the car, I noticed oil leaking onto the pavement. I opened the hood and my AC belt was gone. I took it in to the local service shop and they said when the belt "blew off/exploded etc..."a piece of the belt got wedged in between the crank and crank seal which damaged the seal causing the oil leak. The service shop is installing a new belt/seal as well as changing+refilling the oil as well as cleaning up the oil splatter around the motor. Labor cost was rough. The first time it happened a couple years ago, the belt was still on but shredded like a banana peel.
Being that it has happened twice and from doing research on the belt being an issue, that's what made me ask if I could dragrace without the belt since I'm not concerned about having AC.
