Old 06-26-2020, 06:43 PM   #1
LSA_ZL1
Drives: 2012 Camaro ZL1
Thumbs up is the lsa supercharger capable of making 1000whp+
I need some help with a good parts list for making 1000whp+ on my 2012 camaro ZL1 6-speed, but keeping the stock supercharger. i know i want to run e85. i am looking for a dependable setup. the car is not my daily. ported snout/supercharger? ported heads? what pulley size? injectors?
LSA_ZL1 is offline   Reply With Quote
Old 06-26-2020, 07:16 PM   #2
Vegas Bound
Drives: 2013 Sparkly Red One
Truth be told, it would be a struggle. I'm maxed out at 750 whp with LSA, no porting, stock LS3 heads, GT9 cam, FIC1300 injectors, e85, 2.5/9.5 pulleys, meth injection, headers, CAI, Aux pump.
Adding a bottle could get me there but no thanks.
Vegas Bound is offline   Reply With Quote
Old 06-26-2020, 07:57 PM   #3
pyroguy
Keeper of “THE list”
pyroguy's Avatar
Drives: ABM #832
Yes, but it'll need a little extra help. Check out GuitarmageddonZL1 on YouTube. He made 1,100rwhp with his LSA, cam, and a BIG shot of nitrous.
Check out my build thread
Old 06-26-2020, 10:11 PM   #4
Valkyrie14
Valkyrie14
Valkyrie14's Avatar
Drives: Chevrolet Camaro SS
Kong porting makes a difference. Probably not enough without NOS boost to get over 1000. King is what I’m doing once I complete my other mods.
2014 SS LS3/LSA Supercharger, 10% Super Damper, 2.55 upper, AGP Dual Pump, ID 1050 injectors, Pegasus solid rear cradle bushings, LT Headers, Roto-Fab CAI, Elite E2 catch can, E85 corn fed, 160 Thermostat, Monster Twin Disk, MGW Short Throw shifter, Tick Clutch Master Cylinder, HP Tuners, JL Audio system.
Valkyrie14 is offline   Reply With Quote
Old 06-26-2020, 11:36 PM   #5
sinisterlsx510
sinisterlsx510's Avatar
Drives: 14 ss camaro summit white
I just did a port job on on my newly aquired lsa blower from synergy motorsports but wont have time to test it until i finish gathering the parts for a lsa conversion...but he said best bet id probably get around 700ish and give or take 730ish with e85 and meth...
2014 ss camaro
Stainless works long tubes , rotofab cai , vararam wedge , muffler delete,cat delete ,resonator delete , x pipe
2019 sierra duramax 2500 all terrain x
2001 trans am
Lsx 408 ci rebuild in progress(dead project)
1967 camaro
Sbc 327.
sinisterlsx510 is offline   Reply With Quote
Old 06-27-2020, 12:23 AM   #6
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
For a 6spd car, I think the best you can do is about 820-850 with a ported 1900, 5", 103, aftermarket heads, big cam, e85 (assuming stock displacement). Need NOS or a 2650 to get there in my opinion. But once you are at 1k, you really need more reinforcement in the block and rods/pistons. So you might as well bump the displacement and also buy a 2650.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp // CSP LT's & Ultra Cats // BMR MM // BC Forged KL13
Mods being installed-
oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc.
RobZL1 is online now   Reply With Quote
Old 06-27-2020, 02:09 PM   #7
Russell James
Russell James's Avatar
Don't know why you would want that much with a manual trans. It's just going to blow the tires away, and if it ever did hook - goodbye clutch or trans.
I think a manual ZL1 is incredibly fun with 1 to 2 hundred more horsepower, not more than doubling it. And even then you need to up the cooling, up the intake cooling, ditch the cats. HP = heat. For bumps in hp, need bumps in cooling.
For a "dependable set up" lower hp expectations way down. If truly looking for dependable s/c LS power at 4 digits, just look at some of Bororski's 2650 builds. Dart block, 6 bolt All Pro heads, best rotating assembly and valve train money can buy and a 2650 S/C.
A small supercharger trying to make big power on a relatively large engine starts to kill it's efficiency. It's building way too much intake heat. It's a volumetric efficiency thing. Gale Banks is really one who studies and is the the master of efficient boost. It's not about the boost pressure number - it's about the air fuel charge density and temperature. If you are making big power with a small S/C... on Gale's dyno instruments he would say - that blower is out to lunch.
A small s/c spun fast is more intended for throttle response and mid range. It'll make big boost if forced to, but IATs and charge density will be out to lunch very quick. That first cool dyno pull will be amazing, after that - downhill fast.
Old 06-29-2020, 10:24 AM   #8
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
Kong upgrade. ID1700 injectors, triple pump return fuel system. Forged rotating assembly at least, ARP head stud kit, triple disc clutch just the basics that come to mind. I'd call Ted a Jannetty racing
Greenhornet2 is offline   Reply With Quote
Old 06-29-2020, 11:11 AM   #9
Bo White
Bo White's Avatar
Will need max effort with some spray
Old 06-29-2020, 11:40 AM   #10
hammdo
'It's an experiment'
hammdo's Avatar
I’m in the same boat as Vega Bound. After my latest mods, ~800 to the wheels now (added meth, CAI plus a few extras). NOS or some additional upgrades would be necessary. My cam is setup more for road racing and not a max effort.
-Don
747 RWHP 794 RWTQ
Old 06-29-2020, 12:31 PM   #11
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
Gentleman who works with me has a 14 ZL1 and he has the blower ported, heads, cam ect and put down 830 at the wheel at RPM last year on E85. Seems he was about maxed with it
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
gunchamp is offline   Reply With Quote
Old 06-29-2020, 04:30 PM   #12
Vegas Bound
Funny, LSA_ZL1 asked the question on Friday and hasn't been back to comment since.
1000whp, lsa, pulley upgrade, supercharge, zl1
