06-26-2020, 08:51 PM | #1 |
Drives: 2010 ss/rs 6 speed manual Join Date: Aug 2013
Spark plugs and wires
Ok I started working on doing the headers on my ls3 in my 2010 Camaro ss. Removing the spark plug wires on pass side one of my wires snapped.
Anyways the wires plugs were probably over due for replacement anyways. My motor is bone stock besides bo white tb, adm cai, and now hopefully headers. Looking for recommendations as to what plugs wires should I get? I’d like something a bit better then oem but won’t break the bank either. Also should mention I’m not looking to change coils anytime soon so oem coils for now.
2010 camaro ss/rs, standard 6 speed, ls3 motor, bmr subframe connectors, jba 3” competition Exhaust, stainless works 1 7/8" headers, adm cold air intake, hurst short throw shifter, bo white ported tb, mishimoto aluminum radiator, mishimoto oil cooler.
06-26-2020, 08:54 PM | #2 |
Drives: 2014 2SS/RS Join Date: Jan 2018
OEM are great wires. Unless you are going to throw some significant power down in would just stick with them
2014 2SS/RS LS3/M6
06-26-2020, 08:56 PM | #3 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
Nothing wrong with OEM for stock engines.
06-26-2020, 09:23 PM | #4 |
Drives: 2010 Inferno Orange 2SS/RS Join Date: Apr 2010
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!! https://youtu.be/9JD9it6SmB8 https://youtu.be/xmelTlEzI34 KICKING CANCERS ASS SINCE 2015!! |
06-26-2020, 09:39 PM | #5 |
Cool ty I have no issues going with oem just figured maybe aftermarket might be worth a little extra $. So figured I’d ask for some opinions.
06-26-2020, 09:54 PM | #6 |
Drives: 2015 Camaro SS Join Date: Sep 2011
I have used Taylor 409 high heat wires past and present.
They hold up to the heat from LT headers. You could also just install heat boots over stock wires for protection.
2015 Camaro 2SS Cam/Heads/FBO 498/447 SAE |
06-26-2020, 10:08 PM | #7 |
Valkyrie14
Drives: Chevrolet Camaro SS Join Date: Mar 2020
If you put on headers you will also want heat sleeves to keep your wires from melting.
2014 SS LS3/LSA Supercharger, 10% Super Damper, 2.55 upper, AGP Dual Pump, ID 1050 injectors, Pegasus solid rear cradle bushings, LT Headers, Roto-Fab CAI, Elite E2 catch can, E85 corn fed, 160 Thermostat, Monster Twin Disk, MGW Short Throw shifter, Tick Clutch Master Cylinder, HP Tuners, JL Audio system.
06-26-2020, 10:32 PM | #8 |
Sounds like a good idea where can I find those?
06-27-2020, 08:55 AM | #9 |
I run the Taylor 409's in the red color because of all the custom mods under hood. As OP says, the stockers are a great wire for stock engines. My Taylor's have been on for about 5 yrs now and no issues at all. Have LT's and don't run heat boots on the wires.
06-27-2020, 09:16 AM | #10 |
Drives: 2012 Camaro SS Join Date: Jun 2019
I bought MSD wires because they're red, and red things go faster. No issues with them.
2012 Camaro SS LS3, JRE Scoop, CAI intake, Whipple Supercharger, Fast 85lb injectors, ZL1 pump, McLeod RXT clutch, MGW shifter, Stainless Power 1 7/8 headers w/HFC, Ridetech coilovers, BMR sway bars, trailing arms, toe rods, cradle bushing inserts, 2020 Speed Tuned.
06-27-2020, 09:32 AM | #11 |
Thanks guys I just ordered a set off oem Wires and a set off spark plugs as well.
I should have planned on doing this from the get go and normally I would have. But $ on tighter side of life and was trying to save a few bucks and put it off as the car was running very well.
06-27-2020, 11:18 AM | #12 |
Drives: 2011 Camaro SS Join Date: Jul 2019
MSD Super Conductor wires in red. I've had longtubes for years and don't run any heat shields and have had no problems. Plus they look way better then stock wires. Stick with stock plugs tho.
06-27-2020, 11:22 AM | #13 |
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE Join Date: Feb 2014
Running the Taylors , didn't notice that they worked any better than the oem wires .
OLD GUY FLYING FAST AND LOW
06-27-2020, 11:43 PM | #14 |
Valkyrie14
Summit is where I got mine, but they are pretty common. Local auto part store probably carries them.
