Old 07-03-2020, 04:17 PM   #1
WarDaddy376
WarDaddy376's Avatar
Drives: 2013 SS Camaro
Z28 Suspension Springs
I am thinking about taking off the lowering springs on my 2013 SS2. I can easily find stock used springs on Ebay. What I am thinking would be a 2014/15 complete set of Z28 springs, would they fit like factory? What I would like is if anyone can please provide the GM P/N for front/rear I will do the research on the specs before making the move.
I know Detroit Speed makes a great setup but for some track events I could care less about the lowered look!!
WarDaddy376 is offline   Reply With Quote
Old 07-03-2020, 05:15 PM   #2
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
Just put yours up for sale plus trade for stock ones. Someone will bite
2014 2SS/RS LS3/M6
pnwdan is offline   Reply With Quote
Old 07-03-2020, 05:28 PM   #3
ariZona28
Give speed a chance
ariZona28's Avatar
Mosey on over to the Z/28 section of this forum. Entire sticky devoted to parts. Looks like front springs are part# 22905638. Rears are #22903663. Plenty of other goodies to lighten your wallet if you desire.
ariZona28 is online now   Reply With Quote
Old 07-04-2020, 03:49 PM   #4
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
They will lower the car approximately a inch but the are very stiff, GM put a higher spring rate to make up for a smaller sway bar. So a lot comes into play when using these springs with different sway bars.
I would like to find a set and use with a 28mm front 32 mm rear sway bar with Bilstien B6’s and see how it works.
Orange Krush II
