Old 07-03-2020, 09:22 PM   #1
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
Rocker arm failure
Cruising to work yesterday and I suddenly heard a ticking noise. Was hoping it was an exhaust leak. Popped the hood and it was clearly coming from under the valve cover.
Ordered a set of Yella Terras....
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 07-03-2020, 09:43 PM   #2
pnwdan
pnwdan's Avatar
Drives: 2014 2SS/RS
2014 2SS/RS LS3/M6
pnwdan is offline   Reply With Quote
Old 07-03-2020, 10:15 PM   #3
608RS
608RS's Avatar
Drives: 2015 2ss
glad it was that, and not having the valve drop into the cylinder.
sorry to hear though.
608RS is offline   Reply With Quote
Old 07-03-2020, 10:21 PM   #4
Chris49066SS
Chris49066SS's Avatar
Drives: 2010 SS L99
Clark, did you consider the T&D shaft mount rockers?
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E
Build thread - www.camaro5.com/forums/showthread.php?t=555371
Chris49066SS is offline   Reply With Quote
Old 07-04-2020, 07:53 AM   #5
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
Were those the same ones on your other motor? If so I guess they saw a lot of use.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
zz430camaro is offline   Reply With Quote
Old 07-04-2020, 08:47 AM   #6
xc_SS/RS
Drives: 2010 Camaro SS/RS
Ouch that stinks. Which YT’s did you go with?
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 07-04-2020, 10:48 AM   #7
Clarkstar
Clarkstar's Avatar
No, actually I just bought these from the ws6 store. They have heavy duty trunions. They have a few dyno pulls and 1500 street miles on them.
Old 07-04-2020, 10:49 AM   #8
Clarkstar
Clarkstar's Avatar
YT6667
Old 07-04-2020, 05:22 PM   #9
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Ouch! How much spring force did they see at max lift?
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp // CSP LT's & Ultra Cats // BMR MM // BC Forged KL13
Mods being installed-
oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc.
RobZL1 is offline   Reply With Quote
Old 07-04-2020, 05:42 PM   #10
Bo White
Bo White's Avatar
I'm going with these on my next build.
http://tdmach.com/product/ls3ls9-direct-bolt/
Old 07-05-2020, 02:03 PM   #11
WHAMMO
WHAMMO's Avatar
Drives: 13' 1LE
Solid roller time ...glad you didnt wreck the engine. The TD above looks real promising.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE
Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me.
WHAMMO is offline   Reply With Quote
Old 07-05-2020, 03:03 PM   #12
old motorhead
Drives: Maggie blown LS3 vette
How much do those beauties cost?
old motorhead is offline   Reply With Quote
Old 07-05-2020, 04:12 PM   #13
zz430camaro
Drives: 2015 1LE
I was wondering the same, no price on them. I am sure they won't be cheap, I would probably go with the aluminum shaft ones.
Old 07-05-2020, 05:56 PM   #14
Chris49066SS
Drives: 2010 SS L99
I believe Ryan runs/ran those. Jesel and Crower seem to have good options too but for the price of the T&D shaft mount rockers it seems to be a pretty solid choice. I've considered them after busting one of my stock rockers last year. Thankfully haven't had any further issues though
