![]() Drives: Moneypit Join Date: Nov 2013
ABS-Stabitrak lights again
So after a good run the other day they popped up again after staying away a couple years.
While making a good wot run the road had some dips and it spun pretty good in the upper mph's. Lights came on and I did the battery disconnect etc with no luck. No codes on the HPTuners so I bought the knockoff Tech2 and scanned. It showed left rear wheel speed sensor fault. So i installed new one yesterday after clearing the dtc. It worked for about 2 miles when i went to get gas and after leaving they showed up again, ABS, Stabiltrak, all Traction lights, but NO Check engine light. I just scanned again and it still says left rear sensor probramatic. Any Advice/Thoughts?? Thanks |
![]() ![]() ![]() Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled Join Date: Jun 2019
so the bcm pointed out the obvious.
Yea but wish I could just override them all lol
376 cubic inches of fun
If you are going to do WOT, you need to command competition mode to avoid these error messages.
Yea always turn them all off even if going to store. It’s a habit haha
Last night I swapped in another battery I had and cleared the code again. This morning the lights stayed off until barely to end of my street about 600’ or so. Now thinking do I inspect the hub where the sensor reads? It seems to still run ok. Thanks |
#6 | |
But didn't you say you already replaced a sensor? |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
I think there are some post on here about problems with the speed sensor ring in the hub needing cleaning or replacing?
#8 |
![]() Drives: 15 Camaro 2SS M6 Join Date: Jan 2020
clear the code and record the pid on the left and right at the same time, when the code comes back check the graph. might be the right side double pulsing making it look like the left is lagging.
#9 |
#10 |
Well since I had a $20 credit at Autozone lol, I bought a Moog hub as here is what I found. This piece was imbedded in the ring. It looks like it was part of the thrust washer.
The ring was indeed the issue. Installed the new one and code is gone for now! |
