Old 07-07-2020, 02:08 PM   #1
Limelight
Limelight's Avatar
Drives: 2013 CRT ZL1 coupe
Black side skirts and spoiler/diffuser
What product have people had success using to make the black plastic side skirts and front spoiler/rear diffuser nice and dark black?
A long long time ago I used Armor All on another car and it made the plastic go whiteish coloured so I’ve been hesitant to put anything on the ZL1. But I know it would look so much better darker black.
I have a bottle of 303 Protectant and am thinking of using it when the car is cool and in the shade (never on a hot surface in the sun) - but thought I’d ask and see what others are using...
2013 Camaro ZL1 CRT
IG - crayzl1
Limelight is offline   Reply With Quote
Old 07-07-2020, 02:36 PM   #2
HDRDTD
https://adamspolishes.com/collection...-trim-restorer
Old 07-07-2020, 03:02 PM   #3
Limelight
Limelight's Avatar
^^ Thanks for the link. Interestingly enough however, the reviews on that link are not very flattering at all of this product.
2013 Camaro ZL1 CRT
IG - crayzl1
Old 07-07-2020, 03:22 PM   #4
JBZL1
JBZL1's Avatar
Drives: 2012 ZL1
I use mothers back to black
2012 ZL1 preproduction car #13
ROTO-FAB intake / IC reservoir , 2.85" upper , ported inlet
JBZL1 is offline   Reply With Quote
Old 07-07-2020, 03:33 PM   #5
Coz3z3
Drives: 2015 Z/28, 2015 1LE
I've used the adams one, it doesn't last that long unless you put a protectant over it I think. I used it on an older vehicle and it does seem to only last a month or 2. But I used it on one of my current vehicles and after the cure time I went over it again with their ceramic trim coating and it seems to just be starting to fade to where I should do it again. I applied it back in October
Coz3z3 is offline   Reply With Quote
Old 07-07-2020, 03:43 PM   #6
Happy_Dan
Happy_Dan
Happy_Dan's Avatar
Drives: 2012 IOM Camaro ZL1 #569
Send a message via AIM to Happy_Dan Send a message via Yahoo to Happy_Dan Send a message via Skype™ to Happy_Dan
I used Adams VHT
http://photos.imageevent.com/happy_dan/dantoys/2012camarozl1/websize/Dantequs%20SIG-2.jpg
Happy_Dan is offline   Reply With Quote
Old 07-07-2020, 05:04 PM   #7
GONMAD510
Drives: 2013 ZL1 M6
I saw the same thing on the website. I was actually thinking about ordering some until I saw the reviews.
Fast 850cc Injectors, ATI Balancer, 8.66 Lower Pulley, 2.55 Upper Pulley, Lingenfelter CAI, Kooks LT with cat delete pipes, Noweeds Exhaust Cutouts (extremely loud under full throttle), BTR Stage 3 Cam, BTR Platinum 660 Valve Spring Kit, TR7ix Iridium Spark Plugs, Lingenfelter Solid Isolator, 160 Degree Thermostat, Larger SC Coolant Reservoir with Hose Relocation Kit, BMR 1.25" Lowering Springs, MGW Short Throw Shifter, Racing Brake 2 piece rotors front and rear, Starkweather Performance Custom Dyno Tune on 91 Octane.
691.38 RWHP
630.35 RWTQ
GONMAD510 is offline   Reply With Quote
Old 07-07-2020, 10:13 PM   #8
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
Originally Posted by Happy_Dan View Post
I used Adams VHT
VHT or 303.
ZMEnow is offline   Reply With Quote
Old 07-08-2020, 05:55 AM   #9
fhrex
Drives: 2011 Camaro 2LT/RS
Armor All Outlast works great as well. I use it on my diffuser, grilles, and it makes my rally stripes look like new.
fhrex is offline   Reply With Quote
Old 07-08-2020, 06:57 AM   #10
Happy_Dan
Happy_Dan
Happy_Dan's Avatar
Originally Posted by ZMEnow View Post
VHT or 303.
I am pretty sure it was VHT. It is white stuff. I use is sparingly. wipe it on, clean it off with a clean rag.
I used to used Turtle Wax back to black and it was good but I couldn't find it.
Then I used Zaino leather stuff but it leaves the surface too shiny
Old 07-08-2020, 12:04 PM   #11
ChuckZL1
Drives: Chevy Camaro ZL-1
I have tired all the brands and yet to find one that works at all.
ChuckZL1 is offline   Reply With Quote
Old 07-08-2020, 01:30 PM   #12
silversleeper
Big Crow
silversleeper's Avatar
Drives: '13 ZL1
I use black magic silicon liquid "tire wet" that leaves it oily and collects dirt. Don't smear it on the paint but it doesn't do any damage if you don't like the oilyness. Can be washed off and doesn't turn white like AmorAll.
Or this
https://www.amazon.com/gp/product/B07SHJVK4G/ref
Both the positive and negative reviews on it are true. It streaks on smooth shiny black surfaces like wiper arms or window and roof trim that has more of a painted look. It works great on rough black plastic. It is more similar to a clear coat of paint so handle it accordingly. Clean the surface and ALL water from the edges (waiting time after wash or leaf blower dry) or the water mixes in as you wipe and makes a splotch that's tough to repair. Use blue painters tape around edges of where you wipe so you don't smear on the paint.
On very weathered cars I've used it on wiper arms and tail lights and the other trim too and the slight streaking still looked better than it was before. Don't recommend that on a low mi car that isn't sun beat or the streaking will be worse than any improvement on a near new smooth surface.
silversleeper is offline   Reply With Quote
Old 07-09-2020, 07:59 AM   #13
MichiganMatt
Drives: 2013 ZL1 Convertible
I like Lexol Vinylex, can be used on multiple surfaces and I've been very happy with the UV protection especially on the interior parts. I've owned 4 convertibles over the past 20 years so UV is critical - this product works well on exterior black like the front fascia and rockers too. Gives a great clean satin finish, not recommended if you are looking for a high gloss / high shine pop though.
MichiganMatt is offline   Reply With Quote
Old 07-09-2020, 05:22 PM   #14
mjsmith75
mjsmith75's Avatar
Drives: 2014 ZL1 - White M6
This seems to be the best I have used so far..used on my Seadoos, about to use on the car.
https://www.amazon.com/Solution-Fini...dp/B006NZRAFE/
mjsmith75 is offline   Reply With Quote
