Old 07-07-2020, 09:47 PM   #1
CHRISCAM
CHRISCAM's Avatar
Drives: 2013 Summit White 2SS/1LE
Rotate Rear Wheels to Front?
Anyone out there ever try rotating their rear stock 1LE wheels to the front? I know that they're two different widths, between the fronts and the rears, but I'd like to know if anyone has actually tried it before.
If so, did it rub when turning full lock? Just curious.
Thanks!
CHRISCAM is offline   Reply With Quote
Old 07-07-2020, 11:51 PM   #2
Vegas Bound
Drives: 2013 Sparkly Red One
If 1LE are anything like SS wheels, a spacer is needed for rears to have clearance on the fronts.
Vegas Bound is offline   Reply With Quote
Old 07-08-2020, 01:22 PM   #3
HOJO
HOJO's Avatar
Drives: 2014 Camaro SS/RS 1LE 1967 Camaro
The rears will not work on the front, you will have rubbing issues.
HOJO is offline   Reply With Quote
Old 07-08-2020, 02:06 PM   #4
rgrmoreira13
rgrmoreira13's Avatar
Drives: 2015 2SS 1LE
The rear will not fit in the front.
20x11 in the rear is too big for the front along with rubbing issues
Specs
TSP Stage 2 Boosted Cam 227/235 at 114 LSA
Fore Innovation Triple pump staged (Walbro 342 primary and 2x Walbro 450 secondaries)
Procharger D1x with a 3.85 pulley
ID1050x Injectors
Flex Fuel Sensor
Monster LT1 Twin Disk Clutch
Holley Sniper Efi Intake Manifold
NW 103mm Boosted TB
747rwhp at 12psi on E85
rgrmoreira13 is offline   Reply With Quote
Old 07-08-2020, 09:09 PM   #5
CHRISCAM
CHRISCAM's Avatar
Thanks for the input guys! That's kind of what I thought.
Can't afford $300 a piece new fronts for now, so I'm going to have a shop do a rim swap to put the fronts on the rear wheels to buy myself a little time.
Old 07-08-2020, 10:01 PM   #6
lemontwist
lemontwist's Avatar
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled
so your running a square set up on staggered wheels?
i am pretty confident from post camaro5 that i am safe running square 275/40/20 on 10 inch wide wheels with a+35 offset.....these things look huge to me
https://www.ebay.com/itm/20-20x10-Si...72.m2749.l2649
lemontwist is offline   Reply With Quote
Old 07-09-2020, 09:20 PM   #7
CHRISCAM
CHRISCAM's Avatar
The 1LE has same 285/35/20 both front and rear. It's just that the front wheels are 10" wide and the rears are 11" wide
Old 07-10-2020, 04:31 AM   #8
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Stretching the 285 over the 11 inch rim was supposed to help with turn in for road courses.
Orange Krush II
Old 07-10-2020, 12:50 PM   #9
Groverguy 376
Drives: 2014 AGM SS 1LE 2SS RS
CHRISCAM...I have four (4) OEM Goodyear tires with about 5K "old man driven, babied" miles on them sitting in my basement from my 2014 1LE. I replaced them for "all season" Michelin for mid-west winter driving 2 years ago. All four for the price of one...plus you arrange shipping from Missouri to SoCal (could be expensive???).
Groverguy 376 is offline   Reply With Quote
Old 07-19-2020, 08:54 PM   #10
CHRISCAM
CHRISCAM's Avatar
Thanks for the input, guys. I ended up finding a local mom & pop tire place that happened to have a pair of 295 35 20 Pirelli P-Zeros that were in excellent condition used. They're $350 ea. on Tire Rack, but I got them for $90 for the pair, installed. They also moved my rears to the front.
Next I got a 4-wheel alignment to hopefully cure the inside toe wear that I had on the old fronts.
Hopefully, for just a couple hundred $ I bought myself at least 6 months. Maybe by that time the economy will be a little better and I can grab a pair of new tires!
