Old 07-08-2020, 11:04 AM   #1
pwssycamaro
Drives: Chevy Camaro Ls
Spyder Black LED Tail Lights bulb replacement
I purchased these cool led tail lights for like $40 when I went to go buy a fender from some guy on facebook. 3 months later and my car says "check left rear turn signal lamp". From my knowledge, it means I have to replace the bulb, correct?
pwssycamaro is offline   Reply With Quote
Old 07-08-2020, 08:36 PM   #2
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
LEDs have a lower voltage draw than normal bulbs. Your car thinks they are burned out. You need resistors to prevent the false negative.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 07-08-2020, 08:42 PM   #3
pwssycamaro
Ok, so where can I buy a resistor and what exactly am I looking for when I go there?
Sorry btw, I am pretty clueless when it comes to anything to do with electrical components
Old 07-09-2020, 06:18 AM   #4
'10CamaroDude
Drives: 2010 Camaro LS
If you don't care about the message, do not buy resisters. Walmart sells them though.
They wire in parallel. I don't care about the warning... The whole point for LEDs is
lower power consumption. When you add load resisters, you're bringing the amp load
back up to incandescent levels. If I ever have to use load resisters to get LEDs to
work, then I won't use LEDs. If you need to have the messages go away, then buy
them.
They wire in like another bulb would, so you connect one side to + and the other
side to -. They're not polarized, so that won't matter which way the resister
faces.
'10CamaroDude is offline   Reply With Quote
Old 07-09-2020, 12:40 PM   #5
pwssycamaro
the whole left side is blinking rapidly. would I need to install resistors on both lights on the left therefore needing to install resistors on both tail lights on the right? also, is it vehicle specific?
Old 07-10-2020, 12:32 AM   #6
chevy pilot
chevy pilot's Avatar
Drives: 2010 2SS/RS A6
There is resistor broken in the Spyder tail lights assembly
Old 07-10-2020, 12:43 PM   #7
pwssycamaro
these are the connections to the fast blinking side (driver side). my questions are, is the outer or inner side the side where i add the resistor too? or both? also, which sets of cables do I add it too?
led bulb, spyder, tail light
