Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Garage / Tools Discussions
Old 07-08-2020, 11:06 AM   #1
Level300
Drives: 2015 Black rs/ss/1le
Shout out to Boltdepot.com
I wanted to give a shoutout to boltdepot.com.
This is a great place to buy all sorts of nuts, bolts and fasteners from grade 8 bolts to the smallest screw. They have all sorts of cool fasteners too. They are US based and started as a mom and pop hardware store. They also have a wealth of information on bolts, screws, etc. and templates that you can print for sizing bolts, nuts washers if you’re unsure of it’s size.
If you’re sick of running to the big box stores only to find they don’t stock your bolt or they are sold out, try boltdepot.com.
I discovered them when I couldn’t find a bolt at homedepot or Lowe’s. I had a problem with my order, it was my fault and they fixed it. Awesome company.
Level300 is offline   Reply With Quote
Old 08-16-2020, 12:38 PM   #2
wasthatacop?
wasthatacop?'s Avatar
Drives: 2010 2SS
I'll check them out. I recently installed a camshaft and wanted to replace some of the bolts as I was working. I was surprised to find out that most auto parts store a such as O'Reilly and AutoZone have a small, crappy selection. They told me to go to the tractor parts store and ask.
2010 2SS living in Los Angeles
replaced engine @ 93,000 miles w/ crate engine, camshaft by Comp Cams installed by me, replaced valve train parts,
1.4" BMR lowering springs
ZL1 factory rims
misc: drilled and slotted rotors, fresh air brake cooling system, new speakers, installed reverse camera, muffler delete
wasthatacop? is offline   Reply With Quote
Old 08-16-2020, 04:34 PM   #3
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2011 2SS/RS/A6 cammed-n-whippled
love boltdepot...I order from them all the time.
NY5thgen.com
POWERFREAK is offline   Reply With Quote
