Old 07-08-2020, 08:13 PM   #1
LT1Zob
LT1Zob's Avatar
Drives: 23 LT1 / 19 Z06 / after 6 5th gens
Does the 6th gen TPMS work on a 5th gen (2010)?
Found a set of stock 6th gen SS wheels and tires with sensors for my 2010 RS. I know the offset is slightly off, but otherwise they fit. Not worried about slighly different offset on a street car. My bigger problem is the sensors. Anyone know from experience if 16 sensors work on a 10? Ty
"Make yourself sheep and the wolves will eat you"
LT1Zob is offline   Reply With Quote
Old 07-08-2020, 08:18 PM   #2
Spec
Drives: 2010 Camaro 1SS LS3
I could be wrong, but I believe 6th gen uses 433MHz vs 315MHz in our 5th gens...
Spec is offline   Reply With Quote
Old 07-08-2020, 08:22 PM   #3
Thunderstick
Thunderstick's Avatar
Drives: 14 Camaro LS
I have 6th gen wheels on my 14 and I can confirm the tpms do not work
Sent from my SM-G950U using Tapatalk
Thunderstick is offline   Reply With Quote
Old 07-08-2020, 08:25 PM   #4
LT1Zob
LT1Zob's Avatar
Thank you both. That’s what I was afraid of. Great deal if I could install the wheels/tires and drive, but if I have to dismount 2sets of rims, swap sensors and remount/rebalance, it just doesn’t make sense anymore
Old 07-08-2020, 09:02 PM   #5
xstuntman
Drives: 2012 Victory Red LFX
If your sensors are original then it's time anyhow.
6th gen SS wheels are way nicer than 5th gens.
'18 SS wheels, colored matched Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, victory red rotors and calipers, 1/4 window American flags, splash guards, AEM dry panel air filter, Hot Wheels steering wheel and seat covers, Hot Wheels exterior emblems.
xstuntman is offline   Reply With Quote
Old 07-08-2020, 10:08 PM   #6
LT1Zob
LT1Zob's Avatar
Agreed they're nicer, but not nice enough to put $1,200 into a DD
Old 07-08-2020, 10:09 PM   #7
Excavator3000
Drives: 2015 Camaro SS
hell to the no
Excavator3000 is offline   Reply With Quote
Old 07-08-2020, 10:11 PM   #8
Deputy347k9
Deputy347k9's Avatar
Drives: 2014 Ashen Gray Convertible
Being I enjoy owning now six sets of Camaro OEM wheels I invested in an Autel 601 TPMS Programmer. With this I can use either rubber or metal TPMS sensors, one single sensor can be programmed either 433 or 315. I pay less than $24.00 for new sensors. The Autel 601 will handle just about every car built world wide. With the free updates, I usually update the 601 each fall for new models.
Deputy347k9 is offline   Reply With Quote
Old 07-09-2020, 08:28 AM   #9
Yellow 1
Grumpy Grey-haired Guy
Yellow 1's Avatar
Drives: Camaro, Corvette & Merc C300(daily)
Glad I stumbled across this thread; I got a 5th gen - just about to pull the trigger on some 6th gen ZL1 wheels and now I got a Q - will my fifth gen TPMS sensors swap into the 6th gen rim? - They pretty much a standard component?
(digressing very slightly - we got different frequencies in UK for TPMS, key fobs radios etc etc.... Why'd you guys abandon good ol' English standards?...LOL
Yellow 1 is offline   Reply With Quote
Old 07-09-2020, 11:47 AM   #10
xstuntman
Yeah they are physically the same, just different frequencies.
I bought new 6th SS take offs and also bought new tps sensors while i was at the dealership.
The tire shop programmed in the new GM tps frequency when mounting the new tires.
