Old 07-09-2020, 09:16 AM   #1
moloko
moloko's Avatar
Drives: Camaro V6 2011 and 2014 V6
Camaro with a lot of fuel injections problems and misfires
Since the beginning of this year my Camaro has had fuel injection problems that I haven't been able to solve yet.
I was driving on the road and suddenly the car began to vibrate and the CEL comes out, there was a strong smell of fuel and it had many misfires.
I stopped the car and connected my scanner: P0089 fault with the fuel pressure regulator, P0300 misfires
Towed and the next day it was hard to start but it could start and threw white smoke through the exhaust and then it was half normal, with the difference that the engine felt a little heavy and consumed almost twice as much fuel but works.
Then I changed the injectors peaks for some reconditioned eBay, it started badly but then it was normal, the high fuel consumption continued. I put the old injectors back.
The car didn't use it anymore, it was in storage. Recently I took it out again and it was still running half normal but with the heavy engine and high consumption.
Last week the problem returned, the car started to vibrate, the CEL was turned on with P0089, P0087 (low fuel pressure) and the P0300.
Yesterday we replaced the high pressure pump with an eBay OEM, the problem continues.. It starts up badly, it vibrates a lot, RPM is unstable, it throws fuel down the exhaust and white smoke, says "Reduced engine power" I don't know what to do anymore.. I don't have a lot of money to keep wasting on this car that I just want to get rid of
moloko is offline   Reply With Quote
Old 07-09-2020, 10:58 AM   #2
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
The last time I had symptoms like this, it was not on a Camaro, but on another FI GM car.
The cause turned out to be damage to the FI wire harness, caused by mice.
Rock-It Man is offline   Reply With Quote
Old 07-09-2020, 11:30 AM   #3
MrChrisLS3
Drives: 2018 1SS M6
You did get a code for fault in the fuel pressure regulator.
Your issue is too much fuel. Switching to a high pressure pump would make sense if the issue were not enough fuel.
I would start with the fuel pressure regulator. Or you could have injectors that are stuck open or leaking causing fuel to go into cylinders when it's not supposed to.
Check your oil for gasoline, I would bet there's quite a bit in the crankcase by now.
MrChrisLS3 is offline   Reply With Quote
Old 07-10-2020, 12:25 PM   #4
moloko
moloko's Avatar
What do you mean by FI warness? Any detail would help me find the problem
Old 07-10-2020, 12:36 PM   #5
moloko
moloko's Avatar
Where does the Camaro have a pressure regulator? According to my research, the high-pressure pump is the one that regulates the fuel.
Almost everything I investigated with the code P0087 and P0089 gives as problems the high pressure pump, which in my case when I change it remains the same problem
As I said, I bought 6 reconditioned eBay injectors, I put them in the car but when I started it cold it worked with misfires for a while. I think they came with faults when they were used.
Then a few days ago I reinstalled the old injectors, it started better but now the car is unusable, it vibrates a lot, full of misfires, fuel comes out of the exhaust
I'm going to make a video of how the car is, I have to change the battery first since it died from being stopped for a while
Old 07-10-2020, 06:01 PM   #6
Rock-It Man
Take off the engine cover. You will see all the wiring going to the injectors.
First sign of trouble: acorn shells and mouse poops under the engine cover. This warm and dark space is a favorite nesting area for mice. Then, inspect the wires for signs of gnawing.
Old 07-11-2020, 08:18 AM   #7
MrChrisLS3
Drives: 2018 1SS M6
Seems my first thought was that you had a V8. Looking at your avatar a little closer you have the LLT V6. I could be wrong, as I'm not really to familiar, but didn't the LLT's have a known timing chain problem, skipping teeth, or something like that?
Maybe some others can chime in, but your symptoms sound like it could also be timing related.
Old 07-11-2020, 09:42 AM   #8
moloko
moloko's Avatar
I also thought it might be the timing chain, but in February when we uncovered the engine to change the rocker cover gaskets, we checked with the mechanic and saw that the chains were relatively good, I took these photos.
Plus I didn't get any codes related to the timing chain, just misfire and fuel pressure codes
Old 07-20-2020, 03:52 PM   #9
moloko
moloko's Avatar
the high pressure pump was replaced (except for the hoses) but the problem remains the same.
Misfires, lack of power, white smoke from the exhaust
Old 07-20-2020, 04:35 PM   #10
silversleeper
Big Crow
silversleeper's Avatar
Drives: '13 ZL1
http://www.*************/forum/viewtopic.php?t=392
Here a guy replaces the pressure sensor but IDK why he didn't look at the pressure on the gauge first like he shows at the end, yep low pressure good thing I replaced that $55 sensor for no reason.
My first guess is the in tank fuel pump but checking the fuel pressure wouldn't hurt anything.
Edit: looks like they don't like me to link to that other site, so I'll copy paste what Travis said:
2010 Camaro Fuel System Overview (thanks goes out to Alldata for the useful information)
The fuel system is an electronic returnless on-demand design. A returnless fuel system reduces the internal temperature of the fuel tank by not returning hot fuel from the engine to the fuel tank. Reducing the internal temperature of the fuel tank results in lower evaporative emissions.
An electric turbine style fuel pump attaches to the primary fuel pump module inside the fuel tank. The fuel pump supplies fuel through the fuel feed pipe to the high pressure fuel pump. The high pressure fuel pump supplies fuel to a variable-pressure fuel rail. Fuel enters the combustion chamber through precision multi-hole fuel injectors. The high pressure fuel pump, fuel rail pressure, fuel injection timing, and injection duration are controlled by the engine control module (ECM).
The primary fuel pump module also contains a primary jet pump and a secondary jet pump. Fuel pump flow loss, caused by vapor expulsion in the pump inlet chamber, is diverted to the primary jet pump and the secondary jet pump through a restrictive orifice located on the pump cover. The primary jet pump fills the reservoir of the primary fuel pump module. The secondary jet pump creates a venturi action which causes the fuel to be drawn from the secondary side of the fuel tank, through the fuel transfer pipe, to the primary side of the fuel tank.
Electronic Returnless Fuel System
The electronic returnless fuel system is a microprocessor controlled fuel delivery system which transports fuel from the tank to the fuel rail. It functions as an electronic replacement for a traditional, mechanical fuel pressure regulator. A pressure relief regulator valve within the fuel tank provides an added measure of over pressure protection. Desired fuel pressure is commanded by the engine control module (ECM), and transmitted to the fuel pump flow control module via a GMLAN serial data message. A liquid fuel pressure sensor provides the feedback the fuel pump flow control module requires for Closed Loop fuel pressure control.
Fuel Pump Flow Control Module
The fuel pump flow control module is a serviceable GMLAN module. The fuel pump flow control module receives the desired fuel pressure message from the engine control module (ECM) and controls the fuel pump located within the fuel tank to achieve the desired fuel pressure. The fuel pump flow control module sends a 25 KHz PWM signal to the fuel pump, and pump speed is changed by varying the duty cycle of this signal. Maximum current supplied to the fuel pump is 15 A. A liquid fuel pressure sensor provides fuel pressure feedback to the fuel pump flow control module.
Fuel Pressure Sensor
The fuel pressure sensor is a serviceable 5 V, 3-pin device. It is located on the fuel feed line forward of the fuel tank, and receives power and ground from the fuel pump flow control module through a vehicle wiring harness. The sensor provides a fuel pressure signal to the fuel pump flow control module, which is used to provide Closed Loop fuel pressure control.
Fuel Tank
The fuel tank stores the fuel supply. The fuel tank is located in the rear of the vehicle. The fuel tank is held in place by 2 metal straps that attach to the frame. The fuel tank is molded from high-density polyethylene.
The fuel tank is a saddle configuration in order to provide space for a driveshaft through the center area of the fuel tank. Because of the saddle shape of the tank, two fuel pump modules are required.
Fuel Fill Pipe
The fuel fill pipe has a built-in restrictor in order to prevent refueling with leaded fuel.
Fuel Filler Cap
The fuel fill pipe has a tethered fuel filler cap. A torque-limiting device prevents the cap from being over-tightened. To install the cap, turn the cap clockwise until you hear audible clicks. This indicates that the cap is correctly torqued and fully seated.
Fuel Pump Module
An electric turbine style fuel pump attaches to the primary fuel pump module inside the fuel tank. The fuel pump supplies fuel through the fuel feed pipe to the high pressure fuel pump. The fuel pump module contains a reverse flow check valve. The check valve maintains fuel pressure in the fuel feed pipe in order to prevent long cranking times.
Primary Fuel Pump Module
The primary fuel pump module is located inside of the right side of the fuel tank. The primary fuel pump module consists of the following major components:
* The fuel level sensor
* The fuel pump and reservoir assembly
* The fuel filter
* The pressure relief regulator valve
* The fuel strainer
* The primary jet pump
* The secondary jet pump
Secondary Fuel Pump Module
The secondary fuel pump module is located inside of the left side of the fuel tank. The secondary fuel pump module consists of the following major components:
* The fuel pick-up
Fuel Level Sensor
The fuel level sensor consists of a float, a wire float arm, and a ceramic resistor card. The position of the float arm indicates the fuel level. The fuel level sensor contains a variable resistor which changes resistance in correspondence with the position of the float arm. The engine control module (ECM) sends the fuel level information via the High Speed CAN-Bus to the body control module (BCM). The BCM then sends the fuel level percentage via the Low Speed CAN-Bus to the instrument cluster in order to control the fuel gauge. The control module monitors the signal circuits of the primary fuel level sensor and the secondary fuel level sensor in order to determine the fuel level.
Fuel Pump
The fuel pump is mounted in the fuel pump module reservoir. The fuel pump is an electric pump. Fuel is pumped to the high pressure fuel pump at a pressure that is based on feedback from the fuel pressure sensor. The fuel pump delivers a constant flow of fuel even during low fuel conditions and aggressive vehicle maneuvers. The fuel pump flex pipe acts to dampen the fuel pulses and noise generated by the fuel pump.
Fuel Filter
The fuel filter is located in the primary fuel pump module. The paper filter element traps particles in the fuel that may damage the fuel injection system. The filter housing is made to withstand maximum fuel system pressure, exposure to fuel additives, and changes in temperature.
Pressure Relief Regulator Valve
The pressure relief regulator valve replaces the typical fuel pressure regulator used on a mechanical returnless fuel system. The pressure relief regulator valve is closed during normal vehicle operation. The pressure relief regulator valve is used to vent pressure during hot soaks and also functions as a fuel pressure regulator in the event of the fuel pump flow control module defaulting to 100% pulse width modulation (PWM) of the fuel pump. Due to variation in the fuel system pressures, the opening pressure for the pressure relief regulator valve is set higher than the pressure that is used on a mechanical returnless fuel system pressure regulator.
Fuel Strainer
The fuel strainer attaches to the lower end of the primary fuel pump module. The fuel strainer is made of woven plastic. The functions of the fuel strainer are to filter contaminants and to wick fuel. The fuel strainer normally requires no maintenance. Fuel stoppage at this point indicates that the fuel tank contains an abnormal amount of sediment or contamination.
Primary and Secondary Jet Pumps
The primary jet pump is located in the primary fuel pump module. Fuel pump flow loss, caused by vapor expulsion in the pump inlet chamber, is diverted to the primary jet pump and the secondary jet pump through a restrictive orifice located on the pump cover. The primary jet pump fills the reservoir of the primary fuel pump module.
The secondary jet pump creates a venturi action which causes the fuel to be drawn from the secondary side of the fuel tank, through the transfer pipe, to the primary side of the fuel tank.
Fuel Feed Pipes
The low pressure fuel feed pipe carries fuel from the fuel tank to the high pressure fuel pump.
The fuel feed pipe assembly located in the engine compartment connects the chassis fuel pipe to the high pressure fuel pump. This pipe contains the fuel pulse dampener and the fuel pressure service valve, and is constructed of stainless steel.
The fuel feed intermediate pipe is a high pressure pipe that carries fuel from the high pressure fuel pump to the fuel rail. The fuel feed intermediate pipe is constructed of stainless steel.
Nylon Fuel Pipes
Warning
In order to reduce the risk of fire and personal injury observe the following items:
* Replace all nylon fuel pipes that are nicked, scratched or damaged during installation, do not attempt to repair the sections of the nylon fuel pipes
* Do not hammer directly on the fuel harness body clips when installing new fuel pipes. Damage to the nylon pipes may result in a fuel leak.
* Always cover nylon vapor pipes with a wet towel before using a torch near them. Also, never expose the vehicle to temperatures higher than 115°C (239°F) for more than one hour, or more than 90°C (194°F) for any extended period.
* Apply a few drops of clean engine oil to the male pipe ends before connecting fuel pipe fittings. This will ensure proper reconnection and prevent a possible fuel leak. (During normal operation, the O-rings located in the female connector will swell and may prevent proper reconnection if not lubricated.)
Nylon pipes are constructed to withstand maximum fuel system pressure, exposure to fuel additives, and changes in temperature.
Heat resistant rubber hose or corrugated plastic conduit protect the sections of the pipes that are exposed to chafing, high temperature, or vibration.
Nylon fuel pipes are somewhat flexible and can be formed around gradual turns under the vehicle. However, if nylon fuel pipes are forced into sharp bends, the pipes kink and restrict the fuel flow. Also, once exposed to fuel, nylon pipes may become stiffer and are more likely to kink if bent too far. Take special care when working on a vehicle with nylon fuel pipes.
Quick-Connect Fittings
Quick-connect fittings provide a simplified means of installing and connecting fuel system components. The fittings consist of a unique female connector and a compatible male pipe end. O-rings, located inside the female connector, provide the fuel seal. Integral locking tabs inside the female connector hold the fittings together.
High Pressure Fuel Pump
The high pressure fuel pump is a mechanical one-cylinder design driven by an additional three lobe cam on the exhaust camshaft of bank 2. High pressure fuel is regulated by the high pressure fuel pump actuator, which is a part of the high pressure fuel pump. The high pressure fuel pump actuator is a magnetic actuator which controls the inlet valve of the high pressure fuel pump. The ECM provides battery voltage on the actuator high control circuit and ground on the actuator low control circuit. Both circuits are controlled through output drivers within the ECM. When deactivated, both drivers are disabled and the inlet valve is held open with spring pressure. When activated, the actuator low control circuit driver connects the low control circuit to ground, and the actuator high control circuit driver pulse-width modulates the high control circuit. The ECM uses the camshaft and the crankshaft position sensor inputs to synchronize the actuator with the position of each of the three camshaft lobes. The ECM regulates fuel pressure by adjusting the portion of each pump stroke that provides fuel to the fuel rail. The high pressure fuel pump also contains an integrated pressure relief valve.
Fuel Rail Assembly
The fuel rail assembly attaches to each cylinder head. The fuel rail distributes high pressure fuel to the fuel injectors. The fuel rail assembly consists of the following components:
* The direct fuel injectors
* The fuel rail pressure sensor
Fuel Injectors
The fuel injection system is a high pressure, direct injection, returnless on-demand design. The fuel injectors are mounted in the cylinder head beneath the intake ports and spray fuel directly into the combustion chamber. Direct injection requires high fuel pressure due to the fuel injector's location in the combustion chamber. Fuel pressure must be higher than compression pressure requiring a high pressure fuel pump. The fuel injectors also require more electrical power due to the high fuel pressure. The ECM supplies a separate high voltage supply circuit and a high voltage control circuit for each fuel injector. The injector high voltage supply circuit and the high voltage control circuit are both controlled by the ECM. The ECM energizes each fuel injector by grounding the control circuit. The ECM controls each fuel injector with 65 V. This is controlled by a boost capacitor in the ECM. During the 65 V boost phase, the capacitor is discharged through an injector, allowing for initial injector opening. The injector is then held open with 12 V.
The fuel injector assembly is an inside opening electrical magnetic injector. The injector has six precision machined holes that generate a cone shaped oval spray pattern. The fuel injector has a slim extended tip in order to allow a sufficient cooling jacket in the cylinder head.
Fuel Injection Fuel Rail Fuel Pressure Sensor
The fuel rail pressure sensor detects fuel pressure within the fuel rail. The engine control module (ECM) provides a 5 V reference voltage on the 5 V reference circuit and ground on the low reference circuit. The ECM receives a varying signal voltage on the signal circuit. The ECM monitors the voltage on the fuel rail pressure sensor circuits. When the fuel pressure is high, the signal voltage is high. When the fuel pressure is low, the signal voltage is low.
Fuel Pulse Dampener
The fuel pulse dampener is a part of the low pressure fuel feed pipe assembly. The fuel pulse dampener is diaphragm-operated, with fuel pump pressure on one side and with spring pressure on the other side. The function of the dampener is to dampen the fuel pump pressure pulsations.
Engine Fueling
The engine is fueled by six individual injectors, one for each cylinder, that are controlled by the ECM. The ECM controls each injector by energizing the injector coil for a brief period once every other engine revolution. The length of this brief period, or pulse, is carefully calculated by the ECM to deliver the correct amount of fuel for proper driveability and emissions control. The period of time when the injector is energized is called the pulse width and is measured in milliseconds, thousandths of a second.
While the engine is running, the ECM is constantly monitoring the inputs and recalculating the appropriate pulse width for each injector. The pulse width calculation is based on the injector flow rate, mass of fuel the energized injector will pass per unit of time, the desired air/fuel ratio, and actual air mass in each cylinder, and is adjusted for battery voltage, short term, and long term fuel trim. The calculated pulse is timed to occur as each cylinders intake valves are closing to attain the largest duration and most vaporization.
Fueling during a crank is slightly different than fueling during an engine run. As the engine begins to turn, a prime pulse may be injected to speed starting. As soon as the ECM can determine where in the firing order the engine is, the ECM begins pulsing the injectors. The pulse width during the crank is based on the coolant temperature and the engine load.
The fueling system has several automatic adjustments in order to compensate for the differences in the fuel system hardware, the driving conditions, the fuel used, and the engine aging. The basis for the fuel control is the pulse width calculation that is described above. Included in this calculation are an adjustment for the battery voltage, the short term fuel trim, and the long term fuel trim. The battery voltage adjustment is necessary since the changes in the voltage across the injector affect the injector flow rate. The short term and the long term fuel trims are fine and coarse adjustments to the pulse width that are designed in order to maximize the driveability and emissions control. These fuel trims are based on the feedback from the oxygen sensors in the exhaust stream and are only used when the fuel control system is in a Closed Loop operation.
Under certain condition, the fueling system will turn OFF the injectors for a period of time. This is referred to as fuel shut-off. Fuel shut-off is used in order to improve traction, save fuel, improve emissions, and protect the vehicle under certain extreme or abusive conditions.
In case of a major internal problem, the ECM may be able to use a back-up fuel strategy for limp in mode that will run the engine until service can be performed.
Sequential Fuel Injection
The ECM controls the fuel injectors based on information that the ECM receives from several information sensors. Each injector is fired individually in the engine firing order, which is called sequential fuel injection. This allows precise fuel metering to each cylinder and improves the driveability under all of the driving conditions.
The ECM has several operating modes for fuel control, depending on the information that has been received from the sensors.
Starting Mode
When the ECM detects reference pulses from the crankshaft position sensor, the ECM will enable the fuel pump. The fuel pump runs and builds up pressure in the fuel system. The ECM then monitors the mass air flow (MAF), intake air temperature (IAT), engine coolant temperature (ECT), and the throttle position sensor signal in order to determine the required injector pulse width for starting.
Clear Flood Mode
If the engine is flooded with fuel during starting and will not start, the Clear Flood Mode can be manually selected. To select Clear Flood Mode, push the accelerator to wide open throttle (WOT). With this signal, the ECM will completely turn OFF the injectors and will maintain in this stage as long as the ECM indicates a WOT condition with engine speed below 1,000 RPM.
Run Mode
The run mode has 2 conditions called Open Loop and Closed Loop. When the engine is first started and the engine speed is above 480 RPM, the system goes into Open Loop operation. In Open Loop operation the ECM ignores the signals from the oxygen sensors and calculates the required fuel rail pressure and injector pulse width based primarily on inputs from the MAF, IAT, and ECT sensors.
In Closed Loop, the ECM adjusts the fuel rail pressure and injector pulse width for each bank of injectors based on the signals from each oxygen sensor.
Acceleration Mode
The ECM monitors the changes in the throttle position and the MAF sensor signals in order to determine when the vehicle is being accelerated. The ECM will then increase the fuel rail pressure and injector pulse width in order to provide more fuel for improved performance.
Deceleration Mode
The ECM monitors changes in the throttle position and MAF sensor signals to determine when the vehicle is being decelerated. The ECM will then decrease fuel rail pressure and injector pulse width or even shut-off injectors for short periods to reduce exhaust emissions, and for better, engine braking, deceleration.
Battery Voltage Correction Mode
The ECM can compensate in order to maintain acceptable vehicle driveability when the ECM sees a low battery voltage condition. The ECM compensates by performing the following functions:
* Increasing the injector pulse width in order to maintain the proper amount of fuel being delivered
* Increasing the idle speed to increase the generator output
Fuel Shut-Off Mode
The ECM has the ability to completely turn OFF all of the injectors or selectively turn OFF some of the injectors when certain conditions are met. These fuel shut-off modes allow the ECM to protect the engine from damage and also to improve the vehicles driveability.
The ECM will disable all of the six injectors under the following conditions:
* Ignition OFF-Prevents engine run-on
* Ignition ON but no crankshaft position signal-Prevents flooding or backfiring
* A high engine speed-Above the red line
* A high vehicle speed-Above the rated tire speed
* Closed throttle coast down-Reduces the emissions and increases engine braking.
The ECM will selectively disable the injectors under the following conditions:
* The torque management enabled-Transmission shifts or abusive maneuvers.
* The traction control enabled-In conjunction with the front brakes applying
silversleeper is offline   Reply With Quote
Old 07-27-2020, 10:39 AM   #11
moloko
moloko's Avatar
Here are the datalive values from my Camaro. You can see that the FRP is around 200 PSI or less, it's very low. The new high pressure pump didn't improve anything, I was hoping it would fix it but it didn't.
If someone could please help me. The car has been in storage for over 7 months now. At this moment I don't have much money to keep on changing parts and then everything will be the same. I would appreciate any kind of help, I am desperate
Old 07-27-2020, 10:47 AM   #12
mikeman
Banned
Drives: 2015 Camaro
Did you change the one in the tank yet?
mikeman is offline   Reply With Quote
Old 07-27-2020, 01:32 PM   #13
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
High pressure pump will only work if it has adequate fuel supply. Have you tested line pressure before the high pressure pump to make sure the high pressure pump is being supplied enough fuel? After that I'd be looking at the injectors themselves possibly leaking down
Greenhornet2 is offline   Reply With Quote
Old 07-27-2020, 09:45 PM   #14
theflea42
#938 of 1524
Drives: 2013 Hot Wheels Edition Camaro
If you still suspect something wrong with the fuel injectors, you can take your original ones and have them fixed. Take those ebay injectors and toss them over the hill. The guy that runs this, https://injectorrepair.com/ is pretty good. I sent off a set of factory denso injectors and he fixed them right up.
This might sound stupid, but when you had the valve covers off, did you check to see if any valve springs were broken?
theflea42 is offline   Reply With Quote
