Old 07-09-2020, 12:27 PM   #1
IowaLS31LE
IowaLS31LE's Avatar
Drives: Chevy Camaro SS 1LE
NW 103 TB
Currently have 700whp with whipple supercharger . Thinking about ordering nw tb. Will this fit my k&n cai? Currently have a stock tb .What hp gains might I see?
2.9 whipple, 3.875 pulley, BTR stage 4 pds cam, k&n cai, Kooks 1 7/8 LT headers, Corsa Xtreme 3" catback, mgw shifter, BMR 1.25 springs, ATI super damper, E85, DSX fuel pump and sensor, 127lb injectors
IowaLS31LE is offline   Reply With Quote
Old 07-09-2020, 03:36 PM   #2
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
I was told about 15WHP with a 102NW and a tune. I don't think you need to change the air ducts the inside is larger not the outside. I could be wrong tho.
Greenhornet2 is offline   Reply With Quote
Old 07-10-2020, 10:03 PM   #3
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
You will need a bigger rubber/silicone coupler to go from your CAI to the 102mm (4") TB. Stock TB is about 3.5".
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
Currently @15-16psi....
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 07-12-2020, 12:36 AM   #4
RedRyder
RedRyder's Avatar
Drives: 2010 VR 2SS/RS M6 Camaro
Also will need the 102mm throttle body adapter that whipple sells.
RedRyder is offline   Reply With Quote
Old 07-21-2020, 03:13 PM   #5
Batmanntexas
Not sure which Whipples require this, as mine did not. I unbolted my 90mm and bolted on the 102mm. Now, there was a plastic venturi adapter that came with my Whipple that I used for both the stock and 102mm TB.
-Scott
COTW 9/8/14
Old 07-21-2020, 08:00 PM   #6
RedRyder
RedRyder's Avatar
-Scott
Ya I was talking about that plastic adapter, they make one for 102mm throttle bodies. I guess the stock one fits too but airflow is probably better with the larger one.
