![]() Drives: 2011 Camaro SS ls3 Join Date: Oct 2016
Battery time!!!
well original battery in my 2011 SS
What is the best option? Thanks |
Just replaced mine also, still good, but I thought it was time. 10 years. IMO replace with the exact same battery. Why not?
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
You guys with still-working 10 year old batteries are killing me. I have lived through the winters in Ohio and the moderate climate of CA and have NEVER had a battery last 10 years. Over the course of 46 years and dozens of vehicles.
And my OE battery in my Camaro - in CA, lasted two!
![]() Drives: '10 Camaro SS,Jeep Commander Hemi Join Date: Mar 2010
Battery
My battery was in my car 9 yrs with no problem,still strong,I always put the car away for the winter w/a trickle charger on the battery.I went with an orginal equipment battery because I had such good luck with it.
Come to think of it, I just spent a fortune on a brand new pontoon boat That battery? Lasted 3 DAYS!’Much better on the 2nd one. I must be doing it wrong.
#6 | |
Longest lasting Battery I have ever had! |
#7 |
![]() Drives: 2011 Synergy Green 2SS/RS Join Date: Jun 2014
Mines still going strong too
#8 |
376 cubic inches of fun
I replaced my OEM battery with an OEM battery. Why not?
It was still starting the car, but I began having occasion stabiliti-trak warnings, and the charging voltage never went down, even on long trips. New battery, problem solved. BTW, like Z2880, I live in Massachusetts so my car is hibernating on a tender 6 months out of the year. Last edited by Rock-It Man; 07-12-2020 at 09:37 PM. |
#9 |
The fact my battery is in the trunk and not under the hood helps with longevity. No freezing temps.
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: LT W/2LT,blue metallic Join Date: Jul 2016
replaced mine after 3 years and 6 months.dealer said it was going bad so i bought one at a parts store and put it in,saved about 100 bucks.
#11 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
Still rocking the OEM battery.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
#12 |
Yep, replaced my OEM with an OEM last November.
#13 |
![]() Drives: 2014 Camaro RS 2LT convertible Join Date: Jul 2020
For years I would go through a battery per year on my motorcycle. Finally bought a Tender, and batteries lasted 5+ years even with winter storage. Easy lesson to learn. Now I will be looking for a Tender for the Camaro, and an easy way to connect in between permagrin drives.
#14 |
Banned
Drives: 2012 2SS INFERNO ORANGE Join Date: Apr 2015
myoriginal is 100% perfect...inteligent charger says so..
when mine goes out it'll be replaced with the stock battery |
