Air lift suspension question.. simple
Installed AirLift suspension. 👍
Does anyone that has done this install have pictures of how you routed the stainless whip off of the strut. Just don’t like how mine fits. Thanks
2011 2SS/RS Convertible, Victory Red, Roto-Fab CAI, Stainless Power 1 7/8 headers, No Cats, Straight piped, Bo White TB, Circle D, 3.91, ZL1 CONVERSION, CDC Roll bar and some powder coating and dipping.
What did you end up doing? I don't have any pics at the moment, but this is an issue I'm working on currently.
L.O.D. X1 intake and fuel rails, AGP twin turbo kit with Garret turbos GTX3076r .82ar 57/57,Tial 38mm waste gates, Tial Q 50mm bov, Fore duel fuel pump (twin Walbro 430lph) Fuelab 6 micron inline filter, AUS 1400cc injectors, NGK BR7 spark plugs, GP Tuning stg 2 TT cam, ARP headstuds, BTR valve springs and push rods, Smith Bro's brass trunnion upgrade, Monster LT1-S triple clutch, GFB GForce 3 boost controller, SJM line lock, Lingenfelter LNC-2001 2step, PLX module with Bosch O2 wideband, 800ish whp on 92 @ 14psi, 900ish whp on E60 @ 20psi
I had to remove the strut, loosen the collar, and rotate the bag a quarter turn to put the hose towards the rear.
I have a lot of practice getting struts out. Only 5 bolts after the wheel is off.
