07-16-2020, 06:34 PM | #1 |
Drives: 2016 Camaro SS Vert. Join Date: Apr 2017
Wrong oil filter installed
Amazon sent me the wrong oil filter and like an idiot I changed my oil and installed the wrong filter. They sent me the Wix 57060 instead of the Wix 10290. I plan on changing the filter to the right one, but how much oil should I expect to come out of the oil filter without draining the oil pan? Any help will be greatly appreciated. Thanks
07-16-2020, 06:48 PM | #2 |
I would think that if you let the car sit for a while before removing the filter most of the oil will have gone to the oil pan. My guess is that you wouldn't lose much. Just what's in the filter plus a little more maybe. Just fill the new filter with oil like you normally would before putting it back. Then check the dipstick. I would imaging you would lose less than a quart. But, I've never actually done that. Hopefully someone here has and can give you first hand information on what to actually expect.
07-16-2020, 09:19 PM | #3 | |
07-16-2020, 10:03 PM | #4 |
Drives: 2018 ZLE Join Date: Feb 2018
I woud swap that ASAP. some wrong filters can cause damage, some really don't matter.
07-16-2020, 11:31 PM | #5 |
Ditto the above.
Be sure to pre-fill the new filter to the top before removing the old one to save time. Expect to lose up to about a quart, but if you swap them out fast it should be minimal. Not the end of the world usually, but yes an incorrect filter is typically not advisable.
Gen6 Camaro LT (my daily driver), Cruze ECO (grocery getter), Chevy SS Pickup (wife's daily driver), Honda Shadow, Honda CBX
